Are these the right Brake Discs? - MG-Rover.org Forums
post #1 of 5 (permalink) Old 30-04-2017, 23:53 Thread Starter
I am going to replace both discs on front of my car but are they the right ones?
Link #1
Eicher Premium
Link #2
http://www.ebay.co.uk/itm/Eicher-Pre...MAAOSwymxVJ-mb
I ask this as some listed online are 239mm width and others are 269mm
Will I need to buy anything else like screws or will the current ones be ok?
My car is a 2003, MGZR, 1396, 105 Petrol
dingodoo is offline
post #2 of 5 (permalink) Old 01-05-2017, 08:23
Not if your car has the standard factory fit front brakes - on the 1.4 engined 25/ZR they should be 262mm solid discs.
However, a good many owners have in the past upgraded to either the 262mm vented set-up from the ZR 120 (which require a different caliper from the solid discs), or more commonly to the 282mm vented discs and calipers from the ZR160/ZS180.
If you are unsure, I would suggest having a wheel off and measuring the diameter of your current discs and checking to see if they are solid or vented before ordering any new ones.
The 239mm discs you have seen are for the rear of the ZR/ZS 120, and the 269mm ones are for the rear of the ZR160/ZS180.
post #3 of 5 (permalink) Old 01-05-2017, 15:42 Thread Starter
so are these ok?
Link #1
Eicher Premium
Link #2
Eicher Premium Front 262mm Solid Brake Disc - Rover 25, 45 200, 400 Series & MG | eBay
If these are ok do i need to buy additional screwes to replace the old ones?
ps.
everything on my car is standard factory fitted
dingodoo is offline
post #4 of 5 (permalink) Old 01-05-2017, 20:55
Yes, those are the right ones for the standard set-up on the 1.4 engined cars.
New countersunk screws are not expensive, so perhaps agood idea to have some replacements available, but their only function really is to hold the disc in place when the road wheel isn't fitted. When the wheel is fitted and the wheel nuts tightened, the wheel itself will trap the disc against the hub (some poeple don't even bother fitting the screws).
I usually find the old screws come out fairly easily and without damage by loosening them with a basic impact driver similar to this one: 5pc Impact Screwdriver & Socket Driver Set & Case Mechanics Stuck/Frozen Screws.
post #5 of 5 (permalink) Old 01-05-2017, 21:10 Thread Starter
I will get a mobile mechancic to replace them, i will just get the parts for them to fit, so if screws not needed then will be easier. I already have the pads so need to get the discs as got an advisory last year for mot and they are rusted so best to replace them as mot due in june.
dingodoo is offline
Trouble finding rear brake hose mg zr TD brake discs lacher MG ZR / Rover 25, 200 & Streetwise 13 13-07-2016 14:53
What brake discs do I have ? MGZR120+ MG ZR / Rover 25, 200 & Streetwise 1 17-02-2008 18:36
brake discs soulknight Rover 800 3 01-04-2007 13:28
MG ZR Brake Discs neiljones56 MG ZR / Rover 25, 200 & Streetwise 15 22-12-2005 15:45
New brake discs, how much?? projectgaz Others 4 26-10-2004 20:51
