Track MK2 ZR 160 - Page 11 - MG-Rover.org Forums
 15Likes
post #201 of 266 (permalink) Old 29-05-2016, 08:37 Thread Starter
Originally Posted by tonestf View Post
Whats happened John been waiting for a couple of days for the mapping results, Always enjoy your updates to this thread.
Sorry for late reply, didn't go well was only on rollers for 40mins or so engine wasn't performing right so we knocked it on head. Checked what we could I.e compression, fuel pressure etc but all was ok. Mapper things cam timing is out (which I didn't do as didn't have a digital dti, brackets etc) Ive had to have a break from it tbh cant even bear to look at it at the minute really not sure if I'm going to continue with it as of yet
JOHNDQ is offline
post #202 of 266 (permalink) Old 29-05-2016, 16:57
No... mate you've come too far for any negativity have a break from it for now if it's only cam timing I would book a r/r down at emerald they will set up the cams and through the course of the day alter it for you if it's needed. The good thing with them they are well known for the K. I happily travel 3hrs for a session on their rollers as the support they give is second to none in my opinion. Sometimes its more productive to let some of the fine tuning be done by others. Believe me I know how disappointing a failed mapping session is when I supercharged the TF I ended up re doing the whole pipework as it wouldn't idle but the up shot was that we identified the issue. Besides I want to come down to bedford for a trackday and was hoping you'll be up for showing me around.
JOHNDQ likes this.
tonestf is offline
post #203 of 266 (permalink) Old 29-05-2016, 18:44
Car: Was a Rover 25, now a Rover 75 Connie SE
Agreed. I've followed this project for a while now, and you've done far too much to it just to let something silly like a timing issue to ruin the entire project. Like tonestf said, get it booked in at emerald and let them take care of it for you.
JOHNDQ likes this.
Had an argument with my pet rock recently - Now it's not speaking to me.
Splop is offline
post #204 of 266 (permalink) Old 29-05-2016, 19:52 Thread Starter
Ok right ive had a few days to clam down I bit with it and take a look to flesh. I did try to get hold of emerald because my mapper was busy a while ago. Unfortunately I had no reply from emails and phone line wouldn't connect. Any way I will say what ive done....
Checked ecu settings... All seems ok
Checked compression.... 1-200 2-200 3-210 4-220
Checked supply fuel pressure and regulated pressure... In factory specs
Checked with mapper.... No concerns with knock on rollers
Checked throttle bodies/butterflies.... Again all ok
Checked the timing via lift at DTC best I could with a standard DTI gauge.... Both seem way out I.e....
Settings on exhaust cam using lift at TDC method with the 285h cams from Piper and DVA Power.....
Piper 1.98mm
DVA 2.41mm
And mine.... 1.34mm WTF
I think I probably found the problem there and that's what the mapper thought was the case as engine wasn't responding to fuel/ignition changes.
Ok so what to do next, ive ordered a digital DTI so as to get the best reading possible if there set wrong i will pull out the engine so can get them set up myself 100% right using the timing disk etc.
JOHNDQ is offline
post #205 of 266 (permalink) Old 29-05-2016, 20:04 Thread Starter
Definitely not happy about the position of the vernier either....
JOHNDQ is offline
post #206 of 266 (permalink) Old 30-05-2016, 09:09
That's more like it. If it was easy every one would be doing it.
tonestf is offline
post #207 of 266 (permalink) Old 07-06-2016, 19:43 Thread Starter
Ok quick update, got the brackets made up and a digital DTI and checked the settings....
Intake....
Exhaust....
So exhaust is defo out, got it all set to DVA settings and ran it up engine note has completely changed and it revs up a fair bit faster so fingers crossed on the home path now....
Mean & Green likes this.
JOHNDQ is offline
post #208 of 266 (permalink) Old 26-06-2016, 21:05 Thread Starter
Finally going to get the race seat in while waiting for mapping, got the factory mount out today....
JOHNDQ is offline
post #209 of 266 (permalink) Old 01-07-2016, 20:28 Thread Starter
Got the head lights sorted today, they were in such poor condition were almost completely yellow, since I wasn't planning on using it on road again I painted the lights black but after a rethink I would quite like to attend a few shows next year so thought I would try clean them up. First of used thinners' to remove paint, then a 800-1200 wet flat, cut back with mid then fine compound and a polish all done using the mop. While there I also opened them and painted the black plastic to match wheels etc....
JOHNDQ is offline
post #210 of 266 (permalink) Old 02-07-2016, 17:00
Nice touch careful you don't make it too pretty or you may not want to drive it hard on a circuit. lol
tonestf is offline
post #211 of 266 (permalink) Old 02-07-2016, 18:24
I like that, looks mean and suits a track car. How about doing the fog surrounds too?
Mean & Green is offline
post #212 of 266 (permalink) Old 02-07-2016, 18:52 Thread Starter
I will dont you worry
JOHNDQ is offline
post #213 of 266 (permalink) Old 02-07-2016, 18:54 Thread Starter
Just putting some back to black on those over wise think the orange will be taking over
JOHNDQ is offline
post #214 of 266 (permalink) Old 30-07-2016, 21:22 Thread Starter
Finally got the out and the FIA floor bars welded in and the race seat fitted, only had a steady run out as the map needs redoing but about 4500rpm cars feels pretty quick indeed and the intake noise is amazing. Unfortunately had no idea on speed as no longer have a speedo since ABS has gone but the revs where going up quick....
JOHNDQ is offline
post #215 of 266 (permalink) Old 31-07-2016, 17:12
Headlights look good.
Did you bung the headlights in an electric oven to crack them open ?
ROVER-25X is offline
post #216 of 266 (permalink) Old 31-07-2016, 20:45 Thread Starter
Just a standard oven, 15-20 minutes at 50 degrees done loads of lights that way never had any problems and avoids wrapped plastic
JOHNDQ is offline
post #217 of 266 (permalink) Old 03-08-2016, 20:12
Yeah I did a set of Mk2 headlights a few years back and converted
them to projector HID and opened up a set of ROVER 200 bubble
lights to paint the inside trims black, was just wondering if you had
a different method but the old cool oven trick works wonders.
post #218 of 266 (permalink) Old 10-08-2016, 12:19 Thread Starter
Few more bits done, cleaned up and painted bars and weld's and got harness in....
All approved till 2020
JOHNDQ is offline
post #219 of 266 (permalink) Old 10-08-2016, 23:02
You have 4 years to get your moneys worth then mate.
What is your estimate to getting it on track ?
post #220 of 266 (permalink) Old 11-08-2016, 07:04 Thread Starter
I'm hoping this month just need to get mapping tweeted. Just having trouble getting time off at work as whole of this month theses people off all the time
JOHNDQ is offline
mg zr 160 MORE POWER????? TRACK CAR~!! paddy_c20 MG ZR / Rover 25, 200 & Streetwise 48 18-09-2012 07:13
MG 1.8T ZT (160) Track Car Jflowers Show us your Projects! 9 12-07-2012 04:06
Will this track rod end fit my 160? jshodgson MG ZR / Rover 25, 200 & Streetwise 1 06-08-2011 02:31
MGZR 160 express Track/Show car Track160 For Sale 25 16-07-2009 21:47
MGF 160 vs FTO GR on the track. RossVVC MGF and MGTF (Sponsored by MGFnTFBITZ) 5 22-04-2005 17:13
