Track MK2 ZR 160 - Page 3 - MG-Rover.org Forums
 15Likes
post #41 of 266 (permalink) Old 26-01-2015, 12:05
Car: MG ZS 180
Originally Posted by JOHNDQ View Post
Thanks guys have you two got any trackdays in mind
Don't know yet car's not on the road lol
Looking at MGOT events though
Rockey5uk2001 is offline
post #42 of 266 (permalink) Old 26-01-2015, 14:52
There is a bedford event in the middle of March I was eyeing up I think. I'll check when I get home from work
Will more than likely be in my daily 160 though
Catterall1 is offline
post #43 of 266 (permalink) Old 26-01-2015, 19:15 Thread Starter
MG's on track there this Saturday I'm going on that
JOHNDQ is offline
post #44 of 266 (permalink) Old 28-01-2015, 18:59 Thread Starter
Good news filters came from today and they fit thank god. There only for time being as planning on getting a uprated pedal box so can run a Exige airbox or similar but ok for trackday this Saturday to test out the throttle bodies for real :o Its at Bedford Autodrome with Lotus/MG's on track so if your local come down should be a few nice cars there
JOHNDQ is offline
post #45 of 266 (permalink) Old 28-01-2015, 20:28
Looks great!
Good luck with the track-day!
post #46 of 266 (permalink) Old 28-01-2015, 20:43 Thread Starter
Looks great!
Cheers mate will have some vids from the gopro
JOHNDQ is offline
post #47 of 266 (permalink) Old 28-01-2015, 20:47
Good luck with the track day.
Have you balanced the throttle bodies? It'll be interesting to hear how it's running with standard management, I'd imagine very lean.
Adam Y is offline
post #48 of 266 (permalink) Old 28-01-2015, 22:48 Thread Starter
Thats what i thought all tho believe it or not its a bit rich... lambda sensor switching at idle but when rev's at 2500 on sensor voltage is 0.8volts and have trouble code for running rich Runs ok just has slight flat spot at around 4000prm on light throttle. Still at least its slightly rich better that burning out valve's Fingers crossed will be running Motec ecu soon. Can you balance the VHPD bodies theses no balance screws on them
JOHNDQ is offline
post #49 of 266 (permalink) Old 29-01-2015, 07:26
That is surprising that it's rich. Also odd there are no balance screws although I've not managed to tinker with any vhpd bodies in person. Are they in pairs, otherwise they probably have one control rod working all 4 so should be close enough without having to balance them. There should be some sort of idle adjustment though.
Adam Y is offline
post #50 of 266 (permalink) Old 29-01-2015, 12:17 Thread Starter
Yeah two half's the same but with slightly different linkage that just fit into each other. There's only a screw that opens the butterflies off there stops all tho each side has a vacuum hose linking each half together then another set that are link all four ports together via t-pieces. Will defo be running idle control once get the ECU sorted
JOHNDQ is offline
post #51 of 266 (permalink) Old 29-01-2015, 12:20
The screw that opens the butterfly's will most likely be for your idle control, although it may also help balance them. You really need a flow tester to check them.
Adam Y is offline
post #52 of 266 (permalink) Old 29-01-2015, 16:31 Thread Starter
I'm sure we got some somewhere from when we used to do the SU carbs. I had to give screw a turn in order to open butterflies slightly so it would idle
JOHNDQ is offline
post #53 of 266 (permalink) Old 30-01-2015, 17:28 Thread Starter
Stayed out working on the car till 11pm last night in the freezing cold to make sure everything was ok for Saturdays trackday but at 1pm today got a email saying the event was cancelled due to the weather. Not to happy as i really dont feel its that bad but understand some people didnt feel the same and there are loads of others to do. Anyway quick pic's of the filters and oil catch tank fitted
JOHNDQ is offline
post #54 of 266 (permalink) Old 13-02-2015, 20:13 Thread Starter
Had a evening @ EPS Motorsport tonight to sort out the plans for ZR and get the fuel injectors flow tested and have filters changed. Couldnt believe it all injectors flowed perfect and at 5bar they make best spray pattern and 272cc so good for 244bhp or 210cc at 3bar So we are going with a Emerald K6 control unit with 3 different maps and looking into wideband O2 plus knock control and rolling road/mapping session start of April
JOHNDQ is offline
post #55 of 266 (permalink) Old 18-02-2015, 15:15
would this fit
this is in my tf just waitng for 6/3 for emerald mapping
and you wouldn't need all this gubbins
tonestf is offline
post #56 of 266 (permalink) Old 18-02-2015, 21:05 Thread Starter
I'm ok thanks mate just want to build up to 190ish VHPD spec
JOHNDQ is offline
post #57 of 266 (permalink) Old 19-02-2015, 23:04 Thread Starter
Ok pulled the engine tonight, it needs belts doing, a new clutch and seems to have a fair oil leak now so going to replace said items plus all gaskets and seals and looking into "N" series HG, uprated bolts and oil rail.... as long as liner heights are ok of course
JOHNDQ is offline
post #58 of 266 (permalink) Old 20-02-2015, 14:58 Thread Starter
Engine on stand ready for strip down
JOHNDQ is offline
post #59 of 266 (permalink) Old 24-02-2015, 17:59 Thread Starter
Engine down to block and crank now
Cleaned up some parts today.....
And tomoz have this dirty piece of **** to look forward to
JOHNDQ is offline
post #60 of 266 (permalink) Old 24-02-2015, 18:19
Car: Tomcat/ MG ZR190 Trophy
Get a baffle for the sump while its apart.
Tomcat is offline
mg zr 160 MORE POWER????? TRACK CAR~!! paddy_c20 MG ZR / Rover 25, 200 & Streetwise 48 18-09-2012 07:13
MG 1.8T ZT (160) Track Car Jflowers Show us your Projects! 9 12-07-2012 04:06
Will this track rod end fit my 160? jshodgson MG ZR / Rover 25, 200 & Streetwise 1 06-08-2011 02:31
MGZR 160 express Track/Show car Track160 For Sale 25 16-07-2009 21:47
MGF 160 vs FTO GR on the track. RossVVC MGF and MGTF (Sponsored by MGFnTFBITZ) 5 22-04-2005 17:13
