Track MK2 ZR 160 - Page 4 - MG-Rover.org Forums
 15Likes
post #61 of 266 (permalink) Old 24-02-2015, 18:26 Thread Starter
I found them a while ago but cant for the life of me remember where
JOHNDQ is offline
post #62 of 266 (permalink) Old 28-02-2015, 19:31 Thread Starter
Well as normal job not quite going to be a easy as i thought, liners had dropped slightly, main bearing shells have picked up a bit and steel headgasket had marked the head quite bad so now everythings gone away for a hot wash and skim. Didnt really want to go this far but never mind just decoded the main and big end bearing tables so can get the right ones ordered ago with some liner shims while the head is with engineers
JOHNDQ is offline
post #63 of 266 (permalink) Old 07-03-2015, 11:50 Thread Starter
Busy getting everything cleaned and ready to put back together this week, everything came up really good
Bearing came today too
JOHNDQ is offline
post #64 of 266 (permalink) Old 07-03-2015, 18:58
Car: Tomcat/ MG ZR190 Trophy
Are you going to fit a Piper cam.
Tomcat is offline
post #65 of 266 (permalink) Old 07-03-2015, 19:21 Thread Starter
No not on this one interested to see what it makes stock with throttle bodies for now then later will fit the janspeed manifold and decat and see what difference they make. I plan to get another engine to build upto the full 190 spec as time goes on as have already started getting few bits together
JOHNDQ is offline
post #66 of 266 (permalink) Old 11-03-2015, 07:12
When you fitted the throttle bodies did you drive the car, did it feel any different.
Tomcat is offline
post #67 of 266 (permalink) Old 11-03-2015, 07:56 Thread Starter
Not to sure really on stock ECU had a really bad flat spot at mid range that you had to drive through but throttle was a lot more responsive
JOHNDQ is offline
post #68 of 266 (permalink) Old 11-03-2015, 08:21
Cool
Was that the crossover of the VVC ? I am interested how it develops.
Tomcat is offline
post #69 of 266 (permalink) Old 11-03-2015, 09:14 Thread Starter
It could be yes it felt like ignition timing was out
JOHNDQ is offline
post #70 of 266 (permalink) Old 11-03-2015, 10:49
I couldn't get the ZS running right on the stock ecu with ITB's, that's why I switched to the emerald.
Adam Y is offline
post #71 of 266 (permalink) Old 11-03-2015, 13:13 Thread Starter
Same here what do you think of the Emerald? Do you use the data logging
JOHNDQ is offline
post #72 of 266 (permalink) Old 11-03-2015, 13:21
I'm a big fan of emerald's, have them on all our track cars. The ZS is a pure road car though, my everyday hack as it were, and it works absolutely fine but it does all depend on who maps it and how good they are at mapping. Mine was done at HT Racing at the back of Brands Hatch, same place that mapped out MGB-K, and he did a lot of light throttle work on it. It's a little lumpy on idle until warmed up but that's to be expected on ITB's, other than that it's perfectly fine for everyday use and runs very very well.
I've not used the data logging on it though, never really needed to.
Adam Y is offline
post #73 of 266 (permalink) Old 11-03-2015, 14:32 Thread Starter
Have you bothered with the cold start etc EPS motorsport will be doing the mapping on mine going to run 2 maps so can have a more less standard set up for normal use etc
JOHNDQ is offline
post #74 of 266 (permalink) Old 11-03-2015, 14:48
Yup it has the cold start all set up. Occasionally needs a blip of throttle on really cold mornings but has been fine in temps below 0, just let it warm up for a minute or two before driving off.
Adam Y is offline
post #75 of 266 (permalink) Old 12-03-2015, 23:08 Thread Starter
Cool thanks was in 2 minds on Emerald or Omex as the Emerald doesnt have knock control
JOHNDQ is offline
post #76 of 266 (permalink) Old 12-03-2015, 23:14 Thread Starter
Started to build few bits up today, new bearings, crankshaft and crank all back together now with some Millers assembly lube. Sealant put in correct places and rolled even
JOHNDQ is offline
post #77 of 266 (permalink) Old 22-03-2015, 15:37 Thread Starter
Engine almost done now.....
New and old oil rails...
Block all cleaned ready for liners...
Pistons and liners in, new type N series gasket fitted i also fitted 4thou shims as liners were only sitting level...
Head all bolt on with the new 10.5 grade bolts and new torque setting...
Sealant on and rolled flat...
Cam Carrier, cams and VVC units all in too...
And almost there now...
JOHNDQ is offline
post #78 of 266 (permalink) Old 22-03-2015, 16:53
Car: Rover Streetwise
You must be chuffed to ****
P T C is offline
post #79 of 266 (permalink) Old 22-03-2015, 17:39 Thread Starter
I am but I wont pat my self until its running and leak free
JOHNDQ is offline
post #80 of 266 (permalink) Old 24-03-2015, 20:00 Thread Starter
ECU is here at last Cant really moan about the wait tho as got a really good deal on the unit
JOHNDQ is offline
mg zr 160 MORE POWER????? TRACK CAR~!! paddy_c20 MG ZR / Rover 25, 200 & Streetwise 48 18-09-2012 07:13
MG 1.8T ZT (160) Track Car Jflowers Show us your Projects! 9 12-07-2012 04:06
Will this track rod end fit my 160? jshodgson MG ZR / Rover 25, 200 & Streetwise 1 06-08-2011 02:31
MGZR 160 express Track/Show car Track160 For Sale 25 16-07-2009 21:47
MGF 160 vs FTO GR on the track. RossVVC MGF and MGTF (Sponsored by MGFnTFBITZ) 5 22-04-2005 17:13
