Track MK2 ZR 160 - Page 5 - MG-Rover.org Forums
 15Likes
post #81 of 266 (permalink) Old 29-03-2015, 10:45 Thread Starter
Few more bits today, popped down to DVA power to get a set of Cam seals and a rear crank seal.
Time to start the wiring, i'm moving the Emerald into the car so i will be making up a whole new wiring loom from sratch so ive stripped out the factory loom just to make sure the wiring info i have been sent is correct (which it is) Now just a case of making a list to order all the wires, muti-plugs, terminals etc
JOHNDQ is offline
post #82 of 266 (permalink) Old 29-03-2015, 20:43
following this build with a genuine interest;
For what its worth the rear crank seal when fitted can be secured in place quite easily. Sure it has been raised before but I was advised to do this quick mod by Roger from sabre heads while he was converting a head to mechanical tappets for me.Suppose it just gives a better piece of mind.
tonestf is offline
post #83 of 266 (permalink) Old 29-03-2015, 21:13 Thread Starter
Thanks, I seen that to on a few web sites DVA also said to drill a M6 hole at bottom of crank ladder to allow oil to drill away to help stop future leaks
JOHNDQ is offline
post #84 of 266 (permalink) Old 05-04-2015, 23:10 Thread Starter
Progress been bit slow lately but got the ECU location mocked up today so will shoot down local engineering firm Tuesday to get a nice alloy plate made up
JOHNDQ is offline
post #85 of 266 (permalink) Old 18-04-2015, 18:08 Thread Starter
Made a bit of progress this week....
New timing belt cover came only Rimmer Bro's had this
Engine waiting to meant the gearbox again
Nice new AP clutch
ZR set-up in garage
And at last engine out of kitchen and back where it should be
JOHNDQ is offline
post #86 of 266 (permalink) Old 25-04-2015, 17:24 Thread Starter
On to wiring today the end is in view just need the shielded cable for cam/crank sensors and new muti-plugs for the sensors/injectors etc to turn up now and we'l have a complete new engine wiring loom.
JOHNDQ is offline
post #87 of 266 (permalink) Old 03-05-2015, 20:00 Thread Starter
Nearly have everything for the wiring now just waiting for the brown and grey Junior power timer connectors, bit more shielded cable, few solder sheeves etc etc...
Bit stuck until then so added some "service loops" just before the contacts crimps....
JOHNDQ is offline
post #88 of 266 (permalink) Old 10-05-2015, 21:52 Thread Starter
Ok as long as i haven't missed any thing this should be everything needed to run plus 3 aux gauges, shift light and the clutch switch for "flat shift"
laid out ready for twisting....
Wires all twisted and routed hoping for a test fire next weekend....
JOHNDQ is offline
post #89 of 266 (permalink) Old 23-05-2015, 21:27 Thread Starter
Finally got back on car today....
Removed the 6 pins i needed from the small ECU connector and placed them in there new housings so i didnt have to cut the loom still on the car incase ever has to go back to standard for any reason. These are the out puts to the fuel pump, cooling fan, main relays etc switched from the Emerald
Pins from factory loom into plug.....
And joint into the male plug on my loom....
After a few more checks finally turned on the key, POWER....
And comms
Base VVC map in....
Should be running again tomoz.... i hope
JOHNDQ is offline
post #90 of 266 (permalink) Old 24-05-2015, 15:43
looking good.
Is the engine stock? would be interesting what it makes after a mapping session on the emerald
tonestf is offline
post #91 of 266 (permalink) Old 24-05-2015, 18:20 Thread Starter
looking good.
Other than VHPD throttle bodies yes, ive left all the cam timing etc stock and will be going back to same rolling road with the same tuner later with a better exhaust manifold and de-cat to see what difference that makes
JOHNDQ is offline
post #92 of 266 (permalink) Old 14-06-2015, 20:06 Thread Starter
Not quite the update was hoping for.....
All ran up fine no problems but after around 35-40mins @ fast idle it devolved a small oil leak from front right and rear left corners. Ive checked block and head which are still dead flat, liner heights are still all dead on 4thou and i know everything was 100% clean etc so can only think its a faulty "N" Series gasket.
JOHNDQ is offline
post #93 of 266 (permalink) Old 15-06-2015, 10:19
Gutted for ya JDQ
Please update when you've determined what caused the the oil leak ie gasket as I planned on the N series gasket for the other engine but may just stick to a tried and tested type.
tonestf is offline
post #94 of 266 (permalink) Old 15-06-2015, 12:24 Thread Starter
Gutted for ya JDQ
Will do mate hopefully it should be back together to with the LR MLS gaskets with internal shim not the one with the head saver shim
JOHNDQ is offline
post #95 of 266 (permalink) Old 16-06-2015, 20:14 Thread Starter
Quick update......
Head went back on yesterday...
New new LR MLS gasket...
Head going back on...
Run it up just night and again today and leak seems sorted
JOHNDQ is offline
post #96 of 266 (permalink) Old 19-06-2015, 22:41 Thread Starter
Well since engine now seems ok thought i would treat it to some new track tyre's and the end is hopefully close
JOHNDQ is offline
post #97 of 266 (permalink) Old 20-06-2015, 15:55
Where did you source your slicks from John? I've been having trouble tracking down part worn 17's.
Adam Y is offline
post #98 of 266 (permalink) Old 20-06-2015, 16:03 Thread Starter
There's a set on Ebay at mo mate for 100 type in "slick tyres 17"
JOHNDQ is offline
post #99 of 266 (permalink) Old 22-06-2015, 08:49
Car: bittersweet zs 180 bittersweet zr 105 , escort xr3i , escort rsturbo
So i guess it was a faulty gasket then ?
miss npo is offline
post #100 of 266 (permalink) Old 22-06-2015, 10:29 Thread Starter
Hey you, yeah would seem so still no problems to report touch wood
JOHNDQ is offline
mg zr 160 MORE POWER????? TRACK CAR~!! paddy_c20 MG ZR / Rover 25, 200 & Streetwise 48 18-09-2012 07:13
MG 1.8T ZT (160) Track Car Jflowers Show us your Projects! 9 12-07-2012 04:06
Will this track rod end fit my 160? jshodgson MG ZR / Rover 25, 200 & Streetwise 1 06-08-2011 02:31
MGZR 160 express Track/Show car Track160 For Sale 25 16-07-2009 21:47
MGF 160 vs FTO GR on the track. RossVVC MGF and MGTF (Sponsored by MGFnTFBITZ) 5 22-04-2005 17:13
