where is the ECU and replacing - MG-Rover.org Forums
post #1 of 12 (permalink) Old 11-03-2017, 14:01 Thread Starter
couple of questions
where is the ECU on a 52 plate 1.4?
can I just change the ecu with another 1.4 or 1.6 petrol Rover 25 and do I need to change/program anything?
thanks 2006cdt
2006cdt is offline
post #2 of 12 (permalink) Old 11-03-2017, 14:06
Engine ECU is beside car battery, on the left hand side of the engine bay (right hand side if you are standing in front of open bonnet toward the front of the car).
Engine ECU is paired with alarm ECU and they work with fobs. If you are lloking for new engine ECU you will need to take either as set (engine ECU, alarm ECU with two fobs), or take engine ECU which is programmed not to seek foe alarm ECU, or to go to someone who can do the programming.
post #3 of 12 (permalink) Old 11-03-2017, 14:10 Thread Starter
thank you for the heads up. where is the alarm ecu?
2006cdt
2006cdt is offline
post #4 of 12 (permalink) Old 11-03-2017, 14:12 Thread Starter
is there anyone on this forum with ecu programming equipment?
thanks
2006cdt
2006cdt is offline
post #5 of 12 (permalink) Old 11-03-2017, 14:18
2006cdt
Being 52 plate car I assume she has sqare two button fob? If so, alarm ecu is bolted ont the firewall way above the pedals. Look on the sticky I posted in your another thread.
post #6 of 12 (permalink) Old 11-03-2017, 14:19
thanks
2006cdt
Somebody else will have to step in on this as I cannot help you since I am few thousads miles away from you.
post #7 of 12 (permalink) Old 11-03-2017, 15:36
Dorchester's Avatar
thanks
2006cdt
You may ask @lolsteve98, supporter of this forum. He did a brilliant job for me (mind you that I'm living in France!), fully deactivating the immobiliser on the ECU (and doing as well a fantastic remap): thus I was able to keep my fobs that are working very well with the new ECU.
Dorchester is offline
post #8 of 12 (permalink) Old 11-03-2017, 21:45 Thread Starter
thank you. I'm working my way through possibilities and trying to get information in advance so if I need to use it I have it to hand.
thanks
2006cdt
2006cdt is offline
post #9 of 12 (permalink) Old 11-03-2017, 23:07
Car: (Mgf sold)Zr 120
What's the reason you need to swap the ecu?
Davemgfzr is offline
post #10 of 12 (permalink) Old 12-03-2017, 09:16
^^^^ see his other thread: Rover 25 1.4 wont start.
His daughters boyfriend tried jump starting the car and melted the jump lead insulation - I suspect the leads were connected incorrectly and it has probably fried the engine ECU.
post #11 of 12 (permalink) Old 12-03-2017, 11:18
........or take engine ECU which is programmed not to seek fob alarm ECU,
This happens when the security requirement of the ECU is removed.
where are you?
post #12 of 12 (permalink) Old 12-03-2017, 22:10
lolsteve98's Avatar
Car: ZR VVC
Check the engine bay fuses, had something similar happen to the ZS a while back (jump starting in the dark is asking for trouble) . I believe under closer inspection it turned out to be the main fuse or something of that nature whereas we had also thought it'd done in the ECU
I can reset a second hand ecu to learn the immobiliser codes so it'll run with your car to save messing with fobs and 5as/SCU or Technozen on here does an excellent job at immobiliser free ECUs or you could get a T4 operator to recode the ECU. So plenty of choice.
If you're certain it's the ECU id be happy to check it for you if you post it to me, can then tell you if it is goosed or if something else is amiss.
SAWS Tuning - MGR Remaps
lolsteve98 is offline
replacing rover 45td ecu seaweed Wanted 1 07-09-2013 18:46
Replacing ECU on Diesel ZT StS MG ZT / Rover 75 (Sponsored by Rimmer Bros) 11 10-01-2012 07:34
replacing zr airbag ecu etc etc craigeh123 MG ZR / Rover 25, 200 & Streetwise 5 02-08-2011 22:22
Replacing ECU and 5AS unit? chris.vincent3 MG ZR / Rover 25, 200 & Streetwise 32 11-03-2011 23:14
need ecu resetting or replacing jules1973 England - North 3 08-11-2006 10:12
