Wiring circuit for Electric Windows in Facelifted R25 - MG-Rover.org Forums
post #1 of 8 (permalink) Old 06-10-2008, 11:45 Thread Starter
Car: Rover 45 Impression S3 TDie
Question Wiring circuit for Electric Windows in Facelifted R25
Since Body Control Unit has a fault on it, can anyone supply a way of wiring the electric windows to a separate controller?
Estimates for replacing BCU are currently 712 in Leeds ex-Rover Dealer. Very difficult to get someone to quote me a price as they all want to do their own diagnostics on it (94 a time).
Part numbers of suitable controller would be helpful and wiring diagram or help?
Rover 25 54 plate 3 door car, so just front windows.
Neil :-)
Neil_C_Rover25 is offline
post #2 of 8 (permalink) Old 06-10-2008, 12:45
Car: 25, 75, MG ZR and MG TF
What's actually wrong ?
pete l is offline
post #3 of 8 (permalink) Old 06-10-2008, 22:07 Thread Starter
Hi Pete
The drivers door window won't go up. The switch works in the down position. We have swapped switches with the passenger side and found that the switch is not at fault. The motor is also not at fault.
We have powered the window to the up position and disconnected it under the door card.
Neil
post #4 of 8 (permalink) Old 06-10-2008, 22:39
The good old BCU problem. The only option I have for you is to wire the windows so they just go up and down on each side. That does mean you loose the one touch function.
But let me know. Also I am happy to supply you a diagram for the standard BCU setup. However it wont make much sense to you unless your good with electrics.
Sejin26 is offline
post #5 of 8 (permalink) Old 07-10-2008, 11:04 Thread Starter
Smile
Hi Seijin
To be honest I didn't know the one-touch existed on my car as I always had to keep using the switch to power it up. Does by-passing the BCU mean wiring up the switch straight to the motor? Or do you need a controller?
Are you willing/able to do the job for me? I don't mind travelling as to get it done would be a total relief!!
Neil :-)
post #6 of 8 (permalink) Old 07-10-2008, 19:06 Thread Starter
Bump......
post #7 of 8 (permalink) Old 09-10-2008, 10:24 Thread Starter
Smile
Just purchased a Window Control Unit off eBay so hopefully will be able to direct wire the Driver's window and switch to that instead of going through the BCU.
I see that the passenger window (which works) is controlled by relays so presumably a simpler function in the BCU?
Neil :-)
PS After maybe 50 turns of the ignition the engine warning light is now off!
PPS now to setup my Scanguage2
post #8 of 8 (permalink) Old 15-06-2011, 11:59
wiringg diagram
would be a great help if you could send me the wiring diagram as i have the dreedid bcu fault, just having the windows to work would be a good start, look forward to hearing from you.
Regards
Foggy
foggy18 is offline
R25 Electric Windows 25boi MG ZR / Rover 25, 200 & Streetwise 2 16-08-2007 17:39
Wiring diagram for Bubble electric windows? Friggerpants MG/R Modification & Tuning 2 28-02-2007 00:34
wiring electric windows fog switches etc. fakemail MG ZR / Rover 25, 200 & Streetwise 2 16-06-2006 15:08
electric windows - R25 Impression b21playa MG ZR / Rover 25, 200 & Streetwise 14 22-12-2005 07:40
Is this the facelifted R25? MGROVERnut MG / Rover Related Chat - up to 2005 13 14-07-2003 07:33
