Zr dampers with R25 lowering springs? - MG-Rover.org Forums
post #1 of 5 (permalink) Old 20-03-2017, 20:32 Thread Starter
as the title says, would this work and how much of a drop would I get
Zr dampers with R25 40mm lowering springs
Zr dampers with R25 60mm lowering springs
Or is it best to go for Zr dampers with 30mm lowering springs?
Note, I want to lower the car but also still get through mud and crap down a farm lane!
Alex Prior is offline
post #2 of 5 (permalink) Old 22-03-2017, 20:49
Why not just throw on some Xpower Springs instead, if memory serves the
combined drop with ZR 160 springs was 35mm.
ROVER-25X is offline
post #3 of 5 (permalink) Old 25-03-2017, 16:44
Probably best not to lower at all then if you want to get through mud etc, just put on ZR dampers and stock springs and you'll have a reasonable drop from what you have now on your 25
They dont make or sell xpower springs anymore
ashnyc is offline
post #4 of 5 (permalink) Old 29-03-2017, 12:03
Car: Freelander2 HSE, Mazda 2 Sport, Rover MINI 1380
''just put on ZR dampers and stock springs and you'll have a reasonable drop from what you have now on your 25''
This will make no difference to the ride height at all. The damper bodies on the R25 and MG are the same, it is the spring that lowers the ride height on the MG.
norfie is offline
post #5 of 5 (permalink) Old 29-03-2017, 22:42
If you look hard enough they pop up now and again.
MG ZR 160 shocks/dampers with lowering springs roadboy For Sale 12 30-12-2013 14:25
Zr dampers & P.I. lowering springs.... skrib For Sale 33 21-08-2008 18:40
220/ coupe lowering springs on OE dampers wastincars For Sale 9 05-12-2004 21:22
G-max coupe lowering springs w/ OE dampers wastincars For Sale 9 29-09-2004 11:43
600 lowering springs or dampers + springs putty_thing Wanted 0 18-04-2004 22:40
