ZR - wheel dimensions: offset, width, etc. - MG-Rover.org Forums
post #1 of 22 (permalink) Old 13-11-2005, 09:09 Thread Starter
Thumbs down ZR - wheel dimensions: offset, width, etc.
I've seen some wheels advertised and they are quoted as being "genuine Rover MG ZR wheels", but the seller doesn't know the dimensions of the wheels.
What is the offset and width on the standard 16" wheels that go on ZR's?
And the PCD? 4x??? ?
thanks,
LostBok
LostBok is offline
post #2 of 22 (permalink) Old 13-11-2005, 09:20
They are standard ZR wheels mate.
They are Hairpins, as fitted to the MG ZR and MG ZS
Edit 6.5J x 16
4 x 100 pcd
offset ET45
cjmillsnun is offline
post #3 of 22 (permalink) Old 13-11-2005, 12:36 Thread Starter
thanks CJ, that's the sort of info I was after... they look just like the BBS RX's that I was after for my Golf Mk3. (sorry, yes, I'm a dubber, rather than an MG owner).
Slight concern they're 6.5J - I was after 7J, but that should still fit the 205/45ZR16 rubber I was going to put on them.
Main problem is going to be that I need wheels with ET38, rather than ET45 offset.
Thanks for the prompt info though...
LostBok is offline
post #4 of 22 (permalink) Old 13-11-2005, 12:38
Car: streetwise again.. :)
Send a message via MSN to M4RTIN Send a message via Skype™ to M4RTIN
can't you use some spacers to move the wheels out? someone should make them for the golf
M4RTIN is offline
post #5 of 22 (permalink) Old 13-11-2005, 16:59 Thread Starter
This where my knowledge is slightly lacking - do spacers increase or decrease the offset?
If the offset's already ET45 and I need ET38, aren't spacers just going to push them further and further away from the spec I need?
WRT to the alloy width, would 6.5J be a noticeable difference to 7J? Performance? Feel? Handling? I'd still be wanting to put the 205 width rubber on them (as mentioned before) and according to the Toyo site (http://www.toyo.com/tires/tire_specsheet.cfm?id=20) their 205/45/ZR16's will fit on 6.5J-7.5J, but with what sort of results?
Are the MG "Hairpin" alloys the same as the BBS ones I've been seeing or just very similar?
LostBok is offline
post #6 of 22 (permalink) Old 13-11-2005, 17:03
they just look like the bbs ones..probably made in eastern europe or china
. the smaller the offset number the further away from the hub the centre is, it makes no sense to me tbh lol.
so a et38 will be nearer the edge than et45, so if you use a wide wheel with a low offset it will scrub on the arches
have a google, theres a lot of websites with info.
btw. my tyres are 205x50 r16 and that gives a reasonable ride.. but obviously my alloys are standard fitment so they are bound to work lol
M4RTIN is offline
post #7 of 22 (permalink) Old 13-11-2005, 17:04
Stu
Stu's Avatar
Spacers will decrease the ET number.
But don't do it IMO as you will only be putting extra strain on the nuts/bolts.
Stu
Stu is offline
post #8 of 22 (permalink) Old 13-11-2005, 17:09
Car: Silver Stormer ZR turbo.
ashy is offline
post #9 of 22 (permalink) Old 13-11-2005, 17:10
that offset calculator is very handy
M4RTIN is offline
post #10 of 22 (permalink) Old 13-11-2005, 18:26 Thread Starter
But given that I'd be going from 7J to 6.5J, shouldn't I add 6mm to the offset anyway - so I should be going from ET38 7J's to ET44 6.5J's to keep the wheels in the same place...
That means there's only a 1mm difference....
Also - if I'm staying on 205/45ZR16 tyres? Will the narrow alloys really mess things up?
LostBok is offline
post #11 of 22 (permalink) Old 13-11-2005, 18:28 Thread Starter
Spot the difference:
All I can see is that the BBS has a slightly more noticeable inside lip... just behind the "spokes"....
Cue all the smart-****s in the house say "the bottom one's bigger than the top one"
LostBok is offline
post #12 of 22 (permalink) Old 13-11-2005, 18:28
not really.. if you have 6.5" then you use 205's, i cant think of any other tyre to use.. thats what mine have
M4RTIN is offline
post #13 of 22 (permalink) Old 13-11-2005, 18:54 Thread Starter
Thanks Martin - what profile tyres have you got?
So if I've got this right: moving from a 7J ET38 to a 6.5J ET45 will give me 13mm less width on the outside and 1mm less clearance on the inside...
BUT some previous (17") wheels that I had on the car, had 8.6" wide* rubber (205/40ZR17) and the new tyres are only 8.2" wide* - so I've got 0.2" (5mm) more clearance on each side of the tyre anyway, so I seriously doubt that the 1mm less clearance is going to trouble the Koni's too much!
* figures taken from the tech spec on the Toyo site (since I have Toyo Proxes T1-S).
Only downside is that I'm whittling away the total width of the track of the car...
LostBok is offline
post #14 of 22 (permalink) Old 13-11-2005, 18:56
Stu
Stu's Avatar
A 205 wide 16" tyre is the same width as a 205 wide 17" tyre, so where have you got the difference from?
Stu
Stu is offline
post #15 of 22 (permalink) Old 13-11-2005, 19:02
205x50 R16 are my tires..these are the original ones too so they were the proper fitment
M4RTIN is offline
post #16 of 22 (permalink) Old 13-11-2005, 20:41 Thread Starter
Stu - I'm not sure why - I'm just taking the numbers from the Toyo Proxes spec sheet - every "205 width" has a slightly different inflated width...
edit: here's the Toyo spec sheet http://www.toyo.com/tires/tire_specsheet.cfm?id=20
Martin - thanks - I was just worried about the handling getting wobbly if I had pretty fat tyres sat on the minimum width wheel allowed (for 205's) AND a higher tyre wall, but I was after 45 profile, so that shd be FINE since yours are on 50 profiles...
LostBok is offline
post #17 of 22 (permalink) Old 13-11-2005, 20:51 Thread Starter
What's the normal retail price on these?
Just trying to make sure I'm not being ripped off!
LostBok is offline
post #18 of 22 (permalink) Old 13-11-2005, 21:07
Car: BMW E90
Send a message via MSN to G13SJC
From www.blackcircles.com anything from 38 to 120. I bought Goodyear F1's in this size and paid 80 per tyre.
G13SJC is offline
post #19 of 22 (permalink) Old 13-11-2005, 21:27 Thread Starter
Sorry - G13 - most of this thread has been about the Hairpin alloys , not the tyres - I also use blackcircles to price up rubber (great site!)... I'm just trying to make sure I don't over-pay for the rims, so that's wha tI was after a price on.
Apparently they were offered at about 1000 extra on the cars when new, but I've NEVER used that as a guide - don't worry - I'm not a complete mug I'm not going to pay anything LIKE that... I'm looking for a cheap alternative to my 400 BBS RX's...
LostBok is offline
post #20 of 22 (permalink) Old 15-11-2005, 12:38 Thread Starter
okay - here's a puzzler - what will the "centre bore" be?
LostBok is offline
Question about wheel sizes (tyre width) ajh Others 2 30-04-2006 22:29
ZR 160 wheel offset question sub-zero MG ZR / Rover 25, 200 & Streetwise 0 24-09-2004 21:31
wheel offset evil genius Others 8 20-09-2004 08:50
HELP!! offset and rim width ZR kaser MG/R Modification & Tuning 10 30-07-2004 00:47
Wheels on ZT. Maximum width and offset? ram MG/R Modification & Tuning 0 27-11-2003 11:17
