Brake pedal to floor - Page 2 - MG-Rover.org Forums
post #21 of 30 (permalink) Old 11-07-2013, 09:34
MGJohn's Avatar
Originally Posted by gnelson View Post
John,
Do you have the servo as well. If I am going to change the master cylinder I may as well do the servo at the same time to save stripping it all down twice if the master cylinder is not the cause.
Can I send payment by Paypal or do you prefer a cheque? Can you PM me an email or address?
PM sent.
John.
B>>M>>W ....
MGJohn is offline
post #22 of 30 (permalink) Old 28-07-2013, 18:49 Thread Starter
Car: 45W and 420P Diesels
Unhappy Still no joy
I have now checked all the calipers,changed the front o/s caliper as the bleed screw was unwell, changed the master cylinder and bled about a litre of new fluid through the system. The symptoms are still the same; the pedal slowly sinks to the floor when the engine is running but it is rock hard when the engine is off. Any ideas anyone?
gnelson is offline
post #23 of 30 (permalink) Old 28-07-2013, 20:02
MGJohn's Avatar
How frustrating. So hard to say.
Does the Brake Pedal actually reach the floor under sustained foot pressure?
Many moons ago, my 220 Rover Coupe braked very well indeed but, failed the MoT Brake Pedal Creep test.
I was surprised and queried why and when the MoT tester demonstrated the problem, the front nearside flexible brake pipe to the caliper actually burst showering a nearby technician with a jet of brake fluid !
In previous ownership, the owner had 'upgraded' the front brake pipes with 'expensive' Braided ones. I replaced both sides with OE pipes and the car immediately braked better and passed the retest without delay.
There's always a reason for these things. As always, trick is identifying them.
B>>M>>W ....
MGJohn is offline
post #24 of 30 (permalink) Old 28-07-2013, 20:39
Car: Rover 45 Connie Diesel saloon
clamp each flexible hose off in turn to see if you get a better pedal
how have you bled the system pressure bleeding is a better way also do not reuse any fluid unless it's bee stood for 48 hours you get micro bubbles in the fluid
i use one of these mine is 20 years old now still works well just make sure the tyre pressure is at 20 psi no more or you get a big mess
http://www.ebay.co.uk/itm/Gunson-Eez...item2a2e7e9efa
octo0072000 is offline
post #25 of 30 (permalink) Old 29-07-2013, 08:16 Thread Starter
I didn't reuse any brake fluid - I got 2 litres in before starting the job! I also have an eazibleed but I have been unable to find a cap that will fit my Rovers. I tried making one from an old cap from a scrappy but it lifts and sprays brake fluid all over (even at 10psi tyre pressure). Anyway, I have my wife well trained in bleeding brakes and she has been doing it since she was 10 for her Dad!
I will try clamping each hose in turn as you suggest - that is a great idea which I wish I thought of yesterday!
Thanks - I will let you know next week end.
gnelson is offline
post #26 of 30 (permalink) Old 29-07-2013, 18:40 Thread Starter
Copper sealing washers on brake hose banjos
When I replaced one of the front calipers this weekend, there were no copper sealing washers either side of the banjo joining the flexible hose to the caliper. The Rimmer bros site shows there should be one but the caliper was the original on the car (had it from new) and the hose has never been disconnected before. Is this right? Should there be copper washers, if so one or two (one or both sides of banjo) and what size are they? If they should be present I will have a look at the other calipers on each wheel in turn and fit them as this could presumably be the cause of my brake pedal creep if they have been left off from new? Should they be collapsible washers or can I buy solid ones as from EBay?
gnelson is offline
post #27 of 30 (permalink) Old 29-07-2013, 22:09
MGJohn's Avatar
There should be a slim, thin washer either side of the Banjo Union. They could still be there closely attached to either side of the banjo looking like they are part of the assembly, not loose.
never worked on any Caliper Banjo Union which did not have those slim washers.
B>>M>>W ....
MGJohn is offline
post #28 of 30 (permalink) Old 10-11-2016, 15:12
Car: MG ZTT
I have a similar fault with an auto 400. New master cylinder hasn't fixed it. Also replaced the pressure control valve (unique to the auto model) but still the same. Everything points to the master cylinder but the fault was there before the new m/cyl was fitted so that would seem to cancel that out. The flexi hoses are OK...
MGMetroChamp is offline
post #29 of 30 (permalink) Old 12-11-2016, 03:19
Get someone to press the pedal while you check the hoses. I've never had it, but have heard they can expand when old and worn
Fast Guy is offline
post #30 of 30 (permalink) Old 25-01-2017, 15:08 Thread Starter
Eventually it just disappeared and sorted itself out. Quite bizarre!
gnelson is offline
Brake issue, pedal to the floor biggles160 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 37 23-11-2014 06:03
Brake pedal slowly down to the floor david_geng MG ZT / Rover 75 (Sponsored by Rimmer Bros) 46 30-06-2009 20:30
Brake pedal goes to the floor-mot wuzerk MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 08-06-2009 14:11
URGENT: Brake pedal goes to the floor NickJr. MG ZR / Rover 25, 200 & Streetwise 6 24-09-2008 22:27
my brake pedal slowly goes to floor a2lt16v MG ZS / Rover 45 & 400 12 04-03-2008 22:08
