Car wont start after taking out battery - MG-Rover.org Forums
post #1 of 21 (permalink) Old 24-05-2005, 18:32 Thread Starter
We have two rovers, 414 / 416. We took battery out of each to try in other cars. After putting the battery back in the Rovers the cars will not start at all. When the key is turned a small click coms from engine, but nothing else at all. The car will start however it its bumped started. Any ideas? I'm a total newbie
Thanks.
exit12 is offline
post #2 of 21 (permalink) Old 24-05-2005, 18:52
Car: Jaguar XJ V8
Send a message via MSN to Greg
Sounds like the battery needs a charge. Give it an overnight charge and see how it is tomorrow.
BTW: Love the thread title - "Car won't start after taking out battery" well of course it won't, it's got no battery
Greg is offline
post #3 of 21 (permalink) Old 24-05-2005, 19:25
Tad
Normaly you should input your security code using the driver door key after removing the battery otherwise the car wont start.
Tad is offline
post #4 of 21 (permalink) Old 24-05-2005, 19:35 Thread Starter
LOL.....i fell a right plonker now haha.
Would the car still start with a bump start though? if I didnt put the security code in?
Also we have tried a new battery and nothing, just dead when key is turned, apart from small click coming from a silver type box in engine.
exit12 is offline
post #5 of 21 (permalink) Old 24-05-2005, 19:40
depends wether the battery is flat or if its the imobiliser. if the batterys completly flat, a jump start probebly wont do it, as the engine management wont have enough power
Phil is offline
post #6 of 21 (permalink) Old 24-05-2005, 19:51
No need (if you have the fob)
cjmillsnun is offline
post #7 of 21 (permalink) Old 24-05-2005, 19:59 Thread Starter
I have the fob, which is workin fine.
So the car was working fine...took out the battery...put it back in..car won't turn at all. But will start with a bump or hill start. We did try the security code from the owners manual..still nothing. What should I be looking at next? Its strange how its happened to both cars..exactly same problem after taking out battery and replacing it.
exit12 is offline
post #8 of 21 (permalink) Old 24-05-2005, 20:02
Car: Rover 100
make sure good contact on the earth ,maybe smear some copper ease on to the terminal,you have got them the right way round??
rover in oxon is offline
post #9 of 21 (permalink) Old 24-05-2005, 20:31
Have you checked all the fuses are ok? Sorry I can't more help but I am not too familiar with the 400's. What Reg are they?
andywhitehurst is offline
post #10 of 21 (permalink) Old 24-05-2005, 20:45
I am pretty sure that it's simply a case of reconnecting the battery and it should work. Do other electrical systems work, lights, wipers etc.
Have you had a look at the starter motors? Once my mates car would not start and he was just getting a click yet the car would jump start and it turned out to be a fualty starter motor. Yet it seems strange this could happen on both cars.
It may also be worth checking that you have a good earth, you will need a multimeter, select DC volts (you may have to adjust the range) and connect one probe to the positive teminal + of the battery and the other probe to any earth point on the engine/chasis and you should get around 12.5 V give or take depending on the condition of the battery (engine off).
post #11 of 21 (permalink) Old 24-05-2005, 21:59 Thread Starter
Thanks all...will get all this checked out and post back the findings.
Thank You
exit12 is offline
post #12 of 21 (permalink) Old 24-05-2005, 22:00
Car: Rover 200 Coupe
The first day i got my 214 i took it to Sheffield (to watch football). It had started fine all day. Came out after the game, went to start the car and there was nothing. I tried the key turning thing in the lock cos i thought it might have been the immobiliser. Bump started it and got home. Had a look next day to find the wire had come off the starter motor, the spade connector was really loose
SWFC50 is offline
post #13 of 21 (permalink) Old 25-05-2005, 00:40
Car: Please Select
It may sound obvious but the battery connections need to be tight. the following assumes that the battery is in a charged state and known to be in good order.
The main things that cause this problem are
1. loose or broken earth cable between battery and engine and or battery and body.
2. loose or broken cable between battery positive and starter solenoid (or corroded connection at solenoid or battery end)
3. Ignition switch wire loose, broken or disconnected from back of starter solenoid
4. faulty starter motor (jammed solenoid or seized motor)
5. Blown fuse faulty relay (don't think there are any that would effect the starter on a 414 or 416 though)
Good luck
spliffyuk is offline
post #14 of 21 (permalink) Old 25-05-2005, 00:43
Naj
I thought that if you remoe the battery, you need to re-programe the ECU with the imobiliser or key fob... or am i just stupid...?
Naj is offline
post #15 of 21 (permalink) Old 25-05-2005, 00:50
Richard Moss
Guest
Posts: n/a
Removing and reconnecting the earth lead (as you do when removing the battery) WILL cause the immobiliser to arm. You then need to feed in the Emergency Key Access code (via drivers door lock) or lock/unlock with the fob.
Subsequent failure to turn over could indiacte either a ) wrong EKA codre or b ) low battery vharge.
post #16 of 21 (permalink) Old 25-05-2005, 07:12
Car: 2004 MG ZR 120+
Huh! whats with mine then? I always remove earth lead when doing certain jobs, then re-connect it...car starts, everthings same as before, no problem.
misterreliable is offline
post #17 of 21 (permalink) Old 25-05-2005, 10:46
Sounds like a knacked battery to me.
conkerman is offline
post #18 of 21 (permalink) Old 25-05-2005, 11:32
new battery methinks. cause i took mines back to garage and they fitted one and started fine without having to reset anything. apart from the radio code.
lm25 is offline
post #19 of 21 (permalink) Old 25-05-2005, 11:51
If you have a fob, try pressing the unlock button 5 times or more after the battery has been reconnected. If it won't turn over then, then something ain't right
post #20 of 21 (permalink) Old 25-05-2005, 12:00
Car: Rover 200 mk3 turbo
Doesnt happen on my 200 when I disconnect the battery. Just use the fob like I always have.
However on my 416 Honda Engined BEAST [] to which I have No Fob, when the battery is disconnected I have to enter the EKA code.
Craig
dj_wymo is offline
CAR WONT START! Battery problem? whitelockben MGF and MGTF (Sponsored by MGFnTFBITZ) 6 21-06-2008 21:52
car wont start :-( sugarbunnymg MGF and MGTF (Sponsored by MGFnTFBITZ) 17 29-05-2007 12:22
Rover 214i -wont start after battery swap. MidnighToker 'R8' Rovers (aka Wedges!!) 13 02-09-2006 22:10
battery light car wont start 115 diesel metro leona20003 Metro / Rover 100 8 07-06-2006 11:05
214si flat battery, wont start martin19842 Others 5 22-10-2003 11:52
