Diagnostic codes p0336&p1402 - MG-Rover.org Forums
post #1 of 2 (permalink) Old 06-01-2017, 04:05 Thread Starter
Hi everyvone, I have two code on my zs ( diesel) and i really dont know where it come from , i want to get it sorted out quickly , can you help ?
I have changed the crankshaft sensor , and it seem it resolved some issue with the car but the code is still here
DarkTanner is offline
post #2 of 2 (permalink) Old 06-01-2017, 09:26
Welcome to the forum
I assume that you cleared the codes and they have returned?
If you have replaced the crank position sensor, and the fault code has returned, the next step is to inspect the wiring to the sensor which may be damaged, and check that the contacts in the connector are clean and contacting firmly.
P1402 is related to the exhaust gas recirculation, and it may possibly be resolved by cleaning the EGR valve.
Peugeot & Citroen Key Codes, Transponder Codes & Radio Codes Available Online MG-ROVER-CODES In-Car Audio, Entertainment, Sat Nav etc... 0 13-06-2011 12:38
P1402 P0121 P0113 & P0102 Codes on MG ZR TD+ minshum MG ZR / Rover 25, 200 & Streetwise 6 03-03-2011 14:53
Diagnostic fault codes P1472 & P1475 hambo-180 MG ZS / Rover 45 & 400 4 04-07-2009 11:04
