Erractic idle....running out of ideas - MG-Rover.org Forums
post #1 of 8 (permalink) Old 25-02-2017, 18:45 Thread Starter
Hello,
I have a Rover 45 1.6, 52 plate with 38,000 miles on the clock.
I'm hoping that someone could give me some guidance as I have a recurring erractic idle problem.
The revs are bouncing from around 900rpm to 1500rpm. At one point they were staying at 2000rpm. It is also ocxasionally stuttering on acceleration.
Following the advice on some other posts, the following have been replaced:
Spark Plugs
HT Leads
Ignition Coils
Idle Control Valve.
My brother is a mechanic and is thinking that it may be either the intake manifold gasket (as he is convinced he can hear air being sucked in/expelled). There is also a ratitle on the far left injector.
Or he thought it may be the throttle position sensor...he does not know the frequent/known problems with Rover 45's or the K Series engine.
Hence this post.....if you have any advice I would greatly appreciate it.
Thanks in advance.
Dan
huskydan is offline
post #2 of 8 (permalink) Old 25-02-2017, 22:05
Originally Posted by huskydan View Post
Hello,
Spark Plugs
HT Leads
Ignition Coils
Idle Control Valve.
Thanks in advance.
Dan
I am quite sure you have a leaking input gasket,
A simple test to try is to run engine at tick over from cold, get a trigger sqirty bottle off plain water and squirt it gradually around intake manifold, you should get a difference in engine tone if the water is sucked in at a leaking area, you will hear a marked stutter for a second or two as the water is sucked in to the inlet and affects the firing this will do no harm to the engine but will verify if the gasket is leaking, but I am almost certain it is the problem, if it is, you will have to get the gasket replaced, and also check the plugs,
Hope this helps
Good Luck
moirasrevor is offline
post #3 of 8 (permalink) Old 26-02-2017, 06:23 Thread Starter
Thank you for the advice and the quick reply. I will pass this information onto my brother. I'll update after this has been tried.
Thanks again.
huskydan is offline
post #4 of 8 (permalink) Old 26-02-2017, 10:16
In my experience it could be either, I would try moirasrevor's advice and also clean the IVAC, and the throttle body.
post #5 of 8 (permalink) Old 26-02-2017, 19:56
Car: MG TF 135, MG ZS+ 120
Is the throttle body functioning correctly? Is its operation correct and is it closing fully?
LeRich is online now
post #6 of 8 (permalink) Old 27-02-2017, 05:15 Thread Starter
It seems to be.....my brother is having another look this weekend so I'll ask him to double check
huskydan is offline
post #7 of 8 (permalink) Old 27-02-2017, 16:13
Purely a guess, but I err towards an electrical issue, possibly a simple loose connection. That said, other than the throttle position sensor, I'm not sure where it might be.
Perhaps a code reader would shed some light on the matter.
jdhturner is offline
post #8 of 8 (permalink) Old 11-03-2017, 13:29
6KH
Car: Rover 45, MG ZR 2.0TD, MG ZS 180, MG ZT 260
If it's the inlet manifold gasket you will be losing coolant and the problem (in my experience) is worst at cold start.
I'd go for the IACV and throttle position sensor - remove and clean both or perhaps even replace both, one at a time. Check also the security and routing of the throttle cable over the throttle body drive quadrant.
Andrew
6KH is offline
High Idle.......Any ideas? pbryant_knight MGF and MGTF (Sponsored by MGFnTFBITZ) 24 15-10-2011 14:41
Irratic Idle - any ideas? Mgf120 MG ZR / Rover 25, 200 & Streetwise 4 22-09-2010 14:38
Running out of ideas now help Mostin6556 Rover 600 11 12-09-2009 09:29
I'm running out of ideas! Any help? Ben Richards MG ZR / Rover 25, 200 & Streetwise 8 16-12-2008 07:21
new to this...running out of ideas!!! laura060687 MG ZR / Rover 25, 200 & Streetwise 7 25-09-2008 00:06
