Erratic Tachometer Needle? - MG-Rover.org Forums
post #1 of 6 (permalink) Old 13-05-2017, 07:24 Thread Starter
Hello, was hoping someone could shed some light for me:
My 45 (2003 1.4 with a/c) has developed a bouncing rev counter needle. Sometimes it's fine but at others it will give very strange reading, either sitting at zero or flicking up to speeds that don't equate to what the engine is actually doing
Could someone tell me how this dial works??!
Where does it get the engine speed from? I hoping with this knowledge I'll be able to fix the problem.
(fingers crossed)
monkeygrinder is offline
post #2 of 6 (permalink) Old 13-05-2017, 10:08
Rev counter is getting its signal from engine ECU. Do you have problems only with rev counter or some other instrument or light on cluster is also making problems?
post #3 of 6 (permalink) Old 13-05-2017, 10:12
As above - signal comes from the ECU, if there was a problem before the ECU the car wouldn't run, it has to be a loose plug or damaged wire.
post #4 of 6 (permalink) Old 13-05-2017, 10:25 Thread Starter
Ok then, sounds like I need to check between the ECU and the dash then.
The only other thing not right is that the light behind the odometer is off. I just put that down to a blown bulb.
I'll post back to let you know how I get on. Thank you both for your help. :-)
post #5 of 6 (permalink) Old 13-05-2017, 10:32
That light and erratic behaviour can be connected to same cause.
post #6 of 6 (permalink) Old Yesterday, 08:37
Car: 45 1.4 IL
Mine alternator was on its way out when the needles were jumping around.
I raided scrappy and still have one spare Sat in garage.
Check alternator output at battery terminals. Should be 14v+.
HTH
S!NGH is offline
Rev needle erratic, checked out earths - anything else? Turzyx MG ZS / Rover 45 & 400 7 25-01-2012 16:49
tachometer skysurfer Rover 800 6 20-03-2011 19:51
help!!! erratic temp needle... GB1610 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 14 31-05-2010 07:33
Tachometer rover boi MG ZR / Rover 25, 200 & Streetwise 3 09-08-2008 23:09
Tachometer Lights J.Wildin MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 07-07-2008 21:01
