Front fog lights not working - MG-Rover.org Forums
post #1 of 27 (permalink) Old 10-07-2016, 09:08 Thread Starter
Hi my front fog lights not working when I push in switch there is no light on dash checked fuse it's fine done a visual check on relay that looks fine any help would be appreciated
clarkey8384 is offline
post #2 of 27 (permalink) Old 10-07-2016, 09:10
Little more information will be needed. Did your fogs ever worked?
Is this your first time you tried them, or they stopped working and they worked some time ago?
If they stopped working did some work was done on the car in the meantime?
post #3 of 27 (permalink) Old 10-07-2016, 09:15 Thread Starter
Hi mate only work done was hg last time I used the fogs few weeks ago maybe longer as i dont drive the car that much due to work they were working fine
post #4 of 27 (permalink) Old 10-07-2016, 09:17
Your R45 is mk2 or mk1?
Also, did you turned your dipped beam on or not when tried to light the fogs?
post #5 of 27 (permalink) Old 10-07-2016, 09:30 Thread Starter
Mk 2 and yeah I did mate
post #6 of 27 (permalink) Old 10-07-2016, 09:31 Thread Starter
Mg zs mine is mate same thing as r45 isn't it
post #7 of 27 (permalink) Old 10-07-2016, 09:32
MG ZS is the same as R45. No difference for front fogs.
post #8 of 27 (permalink) Old 10-07-2016, 09:34 Thread Starter
Oh ok mate could it be the switch and how easy is it to replace
post #9 of 27 (permalink) Old 10-07-2016, 09:36
Yes, it could be the switch. It should be the switch out, unplug, plug into new switch and put new switch back into position.
Your rear fogs are working fine?
post #10 of 27 (permalink) Old 10-07-2016, 09:50 Thread Starter
Yeah they are working fine
post #11 of 27 (permalink) Old 10-07-2016, 09:57
Switch or relay would be the first things to check. Replacement with good switch and check with one of the other relays instead of this one should provide answers.
post #12 of 27 (permalink) Old 10-07-2016, 10:00 Thread Starter
Could I put other relay into where the fog relay is if that makes sense ? So I can see if that relay works or won't it work like that ?
post #13 of 27 (permalink) Old 10-07-2016, 10:12
Yes, you can put another relay of the same king in the place where front fogs is, just to check if the present one makes problems. If with new relay you have fogs, then relay is the problem. If not then problem might be the switch.
You can see here where you have relays of the same kind: Rover 400 & 45 / MG ZS: Fuses, Relays, ECUs
post #14 of 27 (permalink) Old 10-07-2016, 10:46 Thread Starter
So you mean the same amp ?
post #15 of 27 (permalink) Old 10-07-2016, 11:00
Same amp, same number of terminals and normaly open for example. This is same kind of relay. I provided you link where you can see where you have same type (same part number) of relay in your car. Take out front fogs relay, and replace with one of those from my link. Then you will be able to check if front fogs are working and if the relay is faulty or not. After that return probing relay in its position, and front fogs relay in its position.
post #16 of 27 (permalink) Old 10-07-2016, 11:27 Thread Starter
OK mate thanks for your advice I will get on it tomoz hopefully what about ecu behind glove box could that be at fault
post #17 of 27 (permalink) Old 10-07-2016, 12:25
I would suggest to check easy things first, relay and switch before we go to suspect BCU unit.
post #18 of 27 (permalink) Old 10-07-2016, 15:34 Thread Starter
Yeah defo mate thank you for all your advice much appreciated
post #19 of 27 (permalink) Old 10-07-2016, 20:09
Bren10's Avatar
If you have a faulty front fog relay in the BCU it's not behind the glove box, it's behind the centre console which means arm rest, radio, switches and console out to do an ohms test on individual relays in the BCU.
I had to change the front fog relay in my BCU when fogs front fogs stopped working. Because I have had various relays fail in BCU including central locking, front fogs, wipers and rear fogs I moved my BCU to new location behind glove box which makes it so much easier to get at. I by passed my drivers window relay by fitting a mk1 unit in the drivers door, the pektron BCU is great when everything is working but a pain when things go wrong and a Deffo weak spot.
Bren10 is offline
post #20 of 27 (permalink) Old 11-07-2016, 16:38 Thread Starter
Well I've tried relay and still not working last thing is the switch hope that works
Both front and rear fog lights not working noj_1991 MG ZR / Rover 25, 200 & Streetwise 6 02-11-2015 21:11
Facelift MG ZR Front Fog Lights Not Working Saints4XLIV MG ZR / Rover 25, 200 & Streetwise 14 14-02-2015 18:26
Fog lights not working markzs MG ZS / Rover 45 & 400 13 15-11-2013 21:08
Fog lights not working spudz MG ZR / Rover 25, 200 & Streetwise 11 29-03-2011 19:43
Hazard & front fog lights not working on ZR facelift g_rossi MG ZR / Rover 25, 200 & Streetwise 3 30-10-2007 22:56
