Fuel smell when opening rear hatch/boot - MG-Rover.org Forums
post #1 of 2 (permalink) Old 04-05-2017, 20:39 Thread Starter
Ed3
Does anyone know where weak point may be to cause a smell of fuel when opening the boot?
I have the five door hatchback Rover 45 2.0td L series 53 plate.
Any tips on whether there are seals by the tank? Any weakness on the fuel inlet pipe? Is the top of the tank prone to rust on the Rover 45?
On my Vauxhall's I would use black waxoyl on most of the underside and any fuel leak would leave an obvious line in the waxoyl.
Ed3 is offline
post #2 of 2 (permalink) Old 04-05-2017, 22:38
Tanks usually rust around the seam first.
There is also an access hatch under the boot carpet which if not done up properly would let the smell in. At some point I think the deleted the access hatch though.
Rear wiper Sounds Like Opening The Boot!!! Moz1987 MG ZR / Rover 25, 200 & Streetwise 4 12-10-2010 14:49
Streetwise -Strange - Heated Rear Window Switch Opening Boot shellyweb MG ZR / Rover 25, 200 & Streetwise 15 25-10-2009 17:58
Hatch opening size AndBurG MG ZR / Rover 25, 200 & Streetwise 1 05-03-2008 11:48
Fuel smell from rear of car Dom BRM MG ZR / Rover 25, 200 & Streetwise 4 15-12-2006 14:10
Wanted mk2 zr rear bumper and boot (hatch) djrushby Wanted 2 01-10-2006 14:58
