Getting Sub wire into engine on MG ZS Facelift - MG-Rover.org Forums
post #1 of 3 (permalink) Old 16-05-2017, 10:44 Thread Starter
Hi, looking for the easiest way to wire in a sub on a MGZS 120 06 model, also need to rewire speaker on passenger side, does that involeve removing the whole doorcard? Or does the speaker grill pop off?
James
James Clouting is offline
post #2 of 3 (permalink) Old 17-05-2017, 13:51
Why do you need to get sub wire into engine bay ? The wire from sub goes to amp. Do you mean the power lead from battery to amp ? If it's the power lead you mean then you just need to release the bolts securing engine bay fusebox and move it to one side. You will then see a large rubber grommet below, that's where you enter the cabin. Pierce the grommet and feed power lead in through hole, I use a metal coat hanger or piece of fence wire and attach to power lead to get in in and down through footwell. It will make it easier if you remove the glove box which is just 2 bolts at bottom of glove box 8mm ( but it can be done with glove box in place just bit harder) Then it's pop off plastic kick plates on sills and tuck wire under carpet and feed through to boot.
Regarding door speaker if you need to get at speaker end connections then yes door card needs removal.
Bren10 is offline
post #3 of 3 (permalink) Old Yesterday, 17:11
Send a message via AIM to MarkTime
Hi James
I'm not sure about your specific model but on my 45 I ran the power cable for the sub through to top right of the engine bay (bottom right of the window) (stage right... i think) which then came into the open of the door/frame then ran it into the plastic bit at the bottom of the inner door frame. Then under all the plastic bits and back seat blahblahblah. Take your remote lead down this route too. The ground cable i put under one of the back seat hinges. Make sure you grind away the paint off the metal first so it has a proper connection.
RCA leads I ran down the middle, under the center console/hand brake cover, then under the carpet to come out under the back seats. Did the same for the speaker wires for my amp/front speakers (if you're planning on doing that too.
As for rewiring your door speaker, again I don't know about your model but on my 45 i had to take the whole panel off. It should be fairly obvious if the grill pops out, and if it does (and if you can see the screws) then you shouldn't have to take the whole panel off.
MarkTime is offline
75 facelift loose wire and plug maiden06 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 14-04-2013 07:15
engine bay wire jason110 MG ZR / Rover 25, 200 & Streetwise 7 19-03-2013 20:26
Engine light on ac wire snapped markycleary Diesel Forum! 0 09-03-2012 19:27
Wire from Engine bay to Cabin Weidass Metro / Rover 100 10 15-11-2011 18:10
Passing wire from engine to the cabin RAINFALLGR MG ZS / Rover 45 & 400 6 07-08-2006 19:38
