glow plug relay - MG-Rover.org Forums
post #1 of 15 (permalink) Old 30-01-2012, 16:21 Thread Starter
glow plug relay
could anyone tell me where the glow plug relay is located
liabilityb is offline
post #2 of 15 (permalink) Old 30-01-2012, 17:26
Car: Two 75s and a 45
I haven't a manual for the 45/ZS but the relay just by the engine management ECU looks like the glow plug relay on mine.
I hope there's someone who can confirm as I want to check mine next weekend.
lowedb is offline
post #3 of 15 (permalink) Old 30-01-2012, 18:39
Mmmm....Rover..
technozen's Avatar
Correct, mounted beside the engine ECU.
technozen is offline
post #4 of 15 (permalink) Old 31-01-2012, 17:41 Thread Starter
many thanks for your help ,the only thing is confusing me is that the part number on rimmer bros show that its a fan relay control ????
post #5 of 15 (permalink) Old 31-01-2012, 18:08
I'd guess the same relay is used for the fan, except the fan one is mounted down in front of the Fans. Mine looks like a similar relay though I haven't had a good look.
lowedb is offline
post #6 of 15 (permalink) Old 31-01-2012, 19:31 Thread Starter
the number on the relay is ywb101200
post #7 of 15 (permalink) Old 31-01-2012, 19:38
Rimmers list that part number for the glow plug relay too from year 2000, though in the place where most relays are listed it also shows as a fan relay, and the glowplug relay is listed with another number.
In any case, we've had it confirmed the one by the engine ECU is the right one. so thanks for that.
lowedb is offline
post #8 of 15 (permalink) Old 31-01-2012, 20:34 Thread Starter
Smile
thanks for all ypur help
post #9 of 15 (permalink) Old 31-01-2012, 20:57
Car: MG ZS MK 2 Saloon Diesel 180kit
so you could exchange them, just to check if you have a faulty relay?
Sponzenbroekske is offline
post #10 of 15 (permalink) Old 31-01-2012, 21:28
It would appear so, though I haven't had a look to be sure. Too cold. Too dark....
lowedb is offline
post #11 of 15 (permalink) Old 31-01-2012, 22:34
The glow plug relay has much bigger contacts and current capacity than the other relays on the car in general.
post #12 of 15 (permalink) Old 01-02-2012, 06:57
I agree, except the fan relay appears to be the same, in having the same part number.
lowedb is offline
post #13 of 15 (permalink) Old 01-02-2012, 08:19
ok so i can try to change it cuz my car is terrible to start with -7 outside :s
post #14 of 15 (permalink) Old 01-02-2012, 10:43
Check to see if the glow plugs are recieving power when the igntion is turned on (n.b. the light on the dash is not connected to the plugs at all).
If no voltage or low voltage then suspect the relay.
post #15 of 15 (permalink) Old 01-02-2012, 10:47
I do wanna do that, but its kinda cold and dark at night, and during the day I work. :s maybe this weekend, cuz this morning its was close!
Glow plug relay johnboy245 MG ZR / Rover 25, 200 & Streetwise 3 14-08-2016 22:22
Glow plug relay coolrooster Diesel Forum! 5 22-02-2010 07:12
Glow plug relay ? mogodon Diesel Forum! 2 26-01-2009 16:56
glow plug relay Liamgray MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 22-03-2008 10:47
Where is my glow plug relay please?! marley MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 11-11-2007 18:06
