Have I balls it up.... - MG-Rover.org Forums
post #1 of 6 (permalink) Old 23-01-2010, 15:47 Thread Starter
Car: Mini (The real one)
Unhappy Have I balls it up....
Just replacing my cam timing wheels after replacing the water pump and general timing belt replacement etc - As I have been doing up the main bolts my cam wheel locking tool fell out and the cam has tured on both wheels....
I have moved the wheel back so trhe timing marks line up again -
Will this be ok to reassemble????
Many Thanks
Jon
(DIYer/bodger)
jonny3979 is offline
post #2 of 6 (permalink) Old 23-01-2010, 16:12
You will be fine!
If the crank is in the Safe (timing) position, you can do what you like with the cams and not cause damage. You only need use the cam locking tool as an assembly aid when fitting the belt.
1955diesel is offline
post #3 of 6 (permalink) Old 23-01-2010, 16:21 Thread Starter
1955diesel - if you were here Id kiss you!!
I had a real feeling I'd ruined all my hard work.....one thing you might know - Haynes says the torque for the cam whells is M8 - Xnm, and M10 65nm...
How do I know which I have??
So grateful....
Jon
post #4 of 6 (permalink) Old 23-01-2010, 16:30
Car: MGTf 2010 + Corsa + Triumph 1050 st sprint
If you measure the thread of the bolts it will let you know which size you have.
Stirling flyer is offline
post #5 of 6 (permalink) Old 23-01-2010, 16:33 Thread Starter
Brilliant - I'm so glad I found this forum!!!
Thank you
Jon
post #6 of 6 (permalink) Old 23-01-2010, 16:51
Err.......... Right. I'll stay here then if you don't mind.
balls!!!!!!!!!!!!!!!!!!!!!! Deano MGF and MGTF (Sponsored by MGFnTFBITZ) 14 05-08-2003 15:01
