Heater/blower Motor help - MG-Rover.org Forums
post #1 of 7 (permalink) Old 11-01-2012, 21:28 Thread Starter
Exclamation Heater/blower Motor help
Hi, looking for some advice.
The heater has completely packed it in on my rover 45. It was working on settings 3 and 4 for a few months, but the other day there was smoke coming out of the fan and it had stopped working.
I had a look through the forum and noticed the thread about changing the resistor. So i opened it up and took it out and its completely knackered. All 3 coils are broken. Is this where the smoke was coming from? or would it be that the motor is needing replaced as well?
If so where would i get one and for how much? I got the resistor panel off ebay for about 15, but couldnt see any motors.
Any help would be appreciated.
Cheers in advance.
lydo33 is offline
post #2 of 7 (permalink) Old 11-01-2012, 23:10
Mmmm....Rover..
technozen's Avatar
Regardless of the state of the resistor pack the fan should run on position 4.
If it doesn't then the motor is most likely faulty.
The 400/45/ZS all use the same motor.
technozen is offline
post #3 of 7 (permalink) Old 11-01-2012, 23:14
Electric motors are pretty tough. Remove the existing one (plus filter if present) and get rid of any crap that's collected. If necessary, clean up the motor so that it rotates freely and maybe check the carbon brushes make contact with the commutator (and generally look ok).
Refit the motor (and a clean filter). If it still doesn't work, even on maximum speed, get a replacement from a scrap yard or from ebay.
You might also consider testing the motor with jump leads direct from the battery, just to make absolutely sure it's dead before replacing it.
Also bear in mind that when a motor burns out, it may take a fuse with it.
jdhturner is offline
post #4 of 7 (permalink) Old 12-01-2012, 08:13 Thread Starter
Thanks guys.
How do I go about getting the motor out, is there a help guide of some sort? Is it easy enough to do?
lydo33 is offline
post #5 of 7 (permalink) Old 12-01-2012, 13:15
Car: 45 2.0 Diesel
Remove Glove box (two 8mm bolts I think)
Remove the metal bar (four bolts - not necessary to get the fan out, but probably need to remove to get at the pollen filter)
Unclip the blower motor wiring plug.
Undo 3 screws underneath blower, and it just drops out. I wouldn't even bother trying to service the old one, should be able to pick one up from a scrappy for peanuts.
Chrisund123 is offline
post #6 of 7 (permalink) Old 12-01-2012, 16:26
When you have the motor sorted out, you can buy up-graded resistors for the resistor pack from rezpax.com. These are said to be pretty impervious to the burn-out problem, and just need to be soldered onto your existing somponent. We just fitted some, total cost around 8.
Mikesmount is offline
post #7 of 7 (permalink) Old 15-01-2012, 20:21 Thread Starter
thanks a lot guys got the motor out and its burnt out right enough. i bought those resistors off rezpax and will get them sorted.
While i had the motor and resistors out tho, i drove the car and it went fine. it has now been lying over the weekend and the battery is flat and its not starting now. do u think this is because ive got those parts out?
lydo33 is offline
Removal of blower / heater motor areed78 MG ZR / Rover 25, 200 & Streetwise 14 12-02-2012 20:11
heater blower motor problem dazz-southeast MG ZR / Rover 25, 200 & Streetwise 1 04-07-2011 01:56
Removing Heater Blower Motor propwash MG ZR / Rover 25, 200 & Streetwise 2 06-02-2011 22:17
414IS blower heater motor differences? Bucko MG ZS / Rover 45 & 400 5 16-12-2010 08:23
Heater blower motor expatmanc MG ZS / Rover 45 & 400 7 18-03-2009 23:23
