Hose hard when cold - valid test? - MG-Rover.org Forums
post #1 of 7 (permalink) Old 18-03-2016, 12:12 Thread Starter
Starting from cool, after about 4 minutes I get hard upper radiator hose with pressure.
Is that an early sign of a blown headgasket, or is it normal?
Bunsen Honeydew is offline
post #2 of 7 (permalink) Old 18-03-2016, 12:35
Depends on which engine. If it is a diesel then a certain sign of head gasket failure if the 4 minutes is spent at idle (Rather than driving it!).
post #3 of 7 (permalink) Old 18-03-2016, 12:54 Thread Starter
Petrol, 1.4 K-series?
post #4 of 7 (permalink) Old 19-03-2016, 14:09
The uppoer hose on my Rover 45 with a 1.8 litre engine takes about 10 to fifteen minutes to pressurise. I presume this happens when the thermostat opens.
Are you losing coolant? Is the oil frothy?
Walkergw6 is offline
post #5 of 7 (permalink) Old 19-03-2016, 17:10
Pressure (and therefore hardness) should develop with temperature.
Four minutes at idle might be sufficient, although my 1.6 would probably take longer.
jdhturner is offline
post #6 of 7 (permalink) Old 19-03-2016, 18:14 Thread Starter
Losing coolant to oil. Was a bit brown, now very light brown (on dipstick).
So need advice as per my other thread as to which gaskets are best (MLS versus alternatives etc)
post #7 of 7 (permalink) Old 20-03-2016, 22:37
Head gasket selection depends on the height of the liners.
Top hose rock hard mcfi5dhc MG ZR / Rover 25, 200 & Streetwise 10 12-03-2014 07:27
top hose hard 75 conni 1.8 geoff 1 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 13-03-2013 15:10
Bottom Hose stone cold Stokiedaz MG ZR / Rover 25, 200 & Streetwise 1 19-11-2007 12:54
Rover 416 - Top coolant hose - hard? Rover_King MG ZS / Rover 45 & 400 8 12-11-2006 15:42
Cold Air Feed Hose? JazzI Others 3 20-08-2002 20:17
