How to remove fuel tank, MG ZS diesel - MG-Rover.org Forums
post #1 of 9 (permalink) Old 06-09-2010, 08:58 Thread Starter
Car: MG ZT-T+ CDTi Auto
Good morning,
Recently my ZS has started to randomly lose power, and I've tracked it down to being crud floating around in the tank (priming bulb gets sucked flat).
Do I need to remove the tank to gain access to the swirl pot, or is there a service cover in the car somewhere? If I need to remove the tank, how would I do so?
Thanks!
Mat
DMGRS is offline
post #2 of 9 (permalink) Old 06-09-2010, 22:19
Car: '02 Volvo V70 + '75 850 Mini
Wink
God, if only there was a hatch! No, Unfortunately you have to drop the tank. First thing is to run it as empty as you can, then remove the filler neck and breather pipe. The actual fuel pipes are on the N/S and disconnct just in front of the wheel then if you look by the O/S suspension mount you will see the connecter for the fuel gauge sender. Finally, support the tank and slacken the two tank strap mounts until they can be unhooked from the body and lower the tank. Good Luck!!
418sld is offline
post #3 of 9 (permalink) Old 07-09-2010, 10:53
Car: ZS+ 170TD
Mat
have you blown through the lines, you might have something small in the pipework rather than crud in the tank....
I assume you have tried it, but figured i would say summit before you go through the effort of dropping the tank
p_b82 is offline
post #4 of 9 (permalink) Old 07-09-2010, 12:57 Thread Starter
Yeah mate done that, keeps coming back though! Getting bored with the taste of diesel now...
DMGRS is offline
post #5 of 9 (permalink) Old 07-09-2010, 13:50
Car: MG ZT+ 135 CDTI facelift Auto + Nissan Micra 1.4 SVE Auto
Talking
Stick with it, it's like Guinness, an acquired taste .
mogodon is offline
post #6 of 9 (permalink) Old 15-09-2010, 17:13 Thread Starter
Right, this is getting worse. It looks like it's a right pain in the backside to remove the fuel pipes, argh!
DMGRS is offline
post #7 of 9 (permalink) Old 16-09-2010, 22:43
Car: now an A3 tdi
I dropped mine and had it back on in a couple of hours,
same thing I had a bit of plastic floating about.
once you lower the tank a few inch you can get to the pipes.
Bob-T is offline
post #8 of 9 (permalink) Old 20-12-2014, 22:06 Thread Starter
Just to update 4 years later - in the end it was a small piece of plastic in the tank too. Hopefully this helps someone with the same issue.
I now have a new ZS with the same issue again.
DMGRS is offline
post #9 of 9 (permalink) Old 20-12-2014, 23:24
yeah yeah u just got to love the taste of diesel really lol :P
Andy400 is offline
How do you remove a diesel fuel injector? DOOD MG ZS / Rover 45 & 400 6 10-08-2009 17:29
In tank diesel fuel pumps. CabPilot MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 07-05-2009 20:02
How do I remove the in-tank fuel pump via access panel in boot? Stevie C Rover 600 3 21-02-2008 18:04
remove fuel tank coopsman1 MG ZR / Rover 25, 200 & Streetwise 1 15-05-2007 12:20
MG ZS Fuel Tank help Robinho MG ZS / Rover 45 & 400 7 25-06-2006 12:30
