Induction Kit for an MG ZS 180 - MG-Rover.org Forums
post #1 of 11 (permalink) Old 23-05-2010, 22:22 Thread Starter
Im thinking about buying an induction KIT for my 180. Any recomendations as there seems to be some difference between the sub 100 pound K & N and the sub 200 pound pipercross one.
Thanks,
Colin.
colscoob is offline
post #2 of 11 (permalink) Old 23-05-2010, 22:44
Car: ZS 180 Mk1 Nightfire
From what I've read in the last few days, the K&N / Pipercross inductions kits for the ZS180 are pretty much a waste of money, because they sit unshielded in the engine bay, and soak up all the hot air (unless you modify the install yourself).
However, from what else I have read on various forums, if you want an all-in-one kit that is worth spending some money on, it's the ITG Maxogen that you want to go for. I've found it here:
http://www.ptp-ltd.co.uk/shop/301_54...ion_system.htm
I've not tried it myself but I'm in the market for one, so I'm doing a lot of reading before any spending!
Hangaku is offline
post #3 of 11 (permalink) Old 24-05-2010, 08:02 Thread Starter
Thanks. I wont be buying anythign right away but the Kit you showed me looks pretty good. I'd be interested to see how you get on with it if you end up going for it.
Thanks,
Colin
colscoob is offline
post #4 of 11 (permalink) Old 24-05-2010, 08:49
Car: S1 Elise 111S/MG ZT 260 SE
I've got an ITG on mine-I'd thoroughly recommend it.
It's a pricey kit (I think I paid around 350 for mine) but it fits perfectly, everything is neat and it makes a lovely noise! Not too chavvy like an open cone but over 3,000rpm it's got a proper touring car style howl.
My car ran 189bhp on Torque of the Devil's (in Uxbridge) rolling road-a Dyno Dynamics unit famed for it's lack of generousity (spelling!?)...
Bear in mind it's a bit of a pain to fit-it's made a lot easier having a ramp, although not impossible on axle stands.
Captain Slow is offline
post #5 of 11 (permalink) Old 24-05-2010, 12:45
Car: MG ZS200, BMW 330i M-Sport, MGF SE 1.8i Wedgewood
Save your money as the main three induction set-ups that work well on the 180 are the ITG Maxogen, expensive but bespoke. Then the BMC CDA which will need some pipework and lastly the open cone situated in the inner wing, again requiring hoses and pipes. All these will give around 10bhp more if executed correctly. I have the BMC fitted, has been on for over 4 years and has been faultless and just requires the normal servicing.
Prior to remapping mine acheived 191bhp coupled with a decat and Janspeed system, so worked for me.
The two you mentioned in post #1 are no good unless you want the noise and can afford to waste fuel.
stamford is offline
post #6 of 11 (permalink) Old 24-05-2010, 14:48
Car: Mk1 MG ZS 180
Sorry to hijack this thread but where did you get your 180 chipped??
I just got myself a BMC and when the new inlet manifold is fitted on wed Im gonna fit it along with a catch tank.
Anyway from what I can see a pipercross viper is a enclosed unit but on top of the 180 you will need a 90 degree elbow to fit it anyway because I dont think there is enough room to just 'bolt' it on so by the time you have got the hose your nearly looking at BMC money anyway.
lawrence-zs180 is offline
post #7 of 11 (permalink) Old 25-05-2010, 13:04
Reidyremaps did mine, highly recommended, I was the guinea pig as it were
Spend wisely on the induction, a good kit and install is well worth the time, money and effort put in. Cold air feed is key too.
stamford is offline
post #8 of 11 (permalink) Old 25-05-2010, 13:19
Car: Mk1 MG ZS 180
Cheers, what sort of figures did you get out of it?
Totally agree about the induction as well.
post #9 of 11 (permalink) Old 25-05-2010, 14:07
They only list remaps for diesel vehicles on their website...
How much did it set you back and are they good basically? as I'm thinking of having mine done.
post #10 of 11 (permalink) Old 25-05-2010, 14:31
Car: Mk1 MG ZS 180
Sent them a email and got a reply saying they did custom rolling road remaps to forum members for 220.. winner!
post #11 of 11 (permalink) Old 25-05-2010, 20:37
Matt Reidy is on here, goes under the username pocketbike_uk I think. He knows his stuff and we spent all day on mine with around 7 dyno runs to achieve 200 on 95RON which wasn't bad. I shall be going back to Matt to get it remapped for 98RON when I have finished a few jobs on my ZS. Last time I was still using the zed for the daily commute, now it is occassional use and now stripped for track use so can afford to tweak it for better grade of fuel.
stamford is offline
ZS 180 Induction Kit Steviec100 MG ZS / Rover 45 & 400 3 14-07-2009 19:53
ZS 180 induction kit? SimmoMGZS MG ZS / Rover 45 & 400 8 06-06-2007 17:43
MG ZS 180 - Induction Kit Moaninsod MG/R Modification & Tuning 14 16-08-2005 16:41
MG ZS 180 Induction Kit Nick G MG/R Modification & Tuning 3 20-04-2003 22:39
mg zs 180 viper induction kit mr paul cudd Product Questions 3 04-10-2002 21:38
