Lost key and fob and clock - MG-Rover.org Forums
post #1 of 11 (permalink) Old 27-01-2015, 14:31 Thread Starter
Hi all
I have lost a key and fob and the price to replace only the fob and programing is I.R.O. 200.
Is there a cheaper way out.
I only have a couple of weeks to sort it out as I am returning it to Spain where it lives.
Any help is much appreciated.
Also the clock.Some of the lights in the LED display don't work and is hard to read. Can this be fixed or is it try to get one out of the scrapyard?.
The car is a zs 180.
Cheers Andy.
dusty123 is offline
post #2 of 11 (permalink) Old 27-01-2015, 15:20
Clock is fixable with an iron, sorted mine out that way.
https://www.youtube.com/watch?v=nsz8vwW8L7E
Rusty! is offline
post #3 of 11 (permalink) Old 27-01-2015, 16:05
Depends which type fob is required.
If you have a pre-facelift ZS with a black lozenge shaped fob, you can get a second hand one - these type can be reprogrammed to another car for a relatively small amount by anyone with suitable equipment (any auto locksmith should be able to do it). Just make sure you get either a 17TN or 3TXB type.
If you have a facelift ZS with a black and grey round Pektron fob, you have little option but to buy a brand new fob complete with its unique barcode. The barcode tells the SCU the initial starting code of the fob, which then rolls on each time the buttons are pressed. Once they have been used above a certain number of times, the SCU will no longer recognise the fob from the original barcode, thus making it impossible to reprogram a used one to another car.
In the case of the round Pektron fob, you best option is to contact technozen (either by pm on this forum http://forums.mg-rover.org/members/technozen-181/, or via his website http://www.technozen-electronics.co.uk/). He did have brand new fobs available for a lot less than the XPart list price.
post #4 of 11 (permalink) Old 27-01-2015, 17:19 Thread Starter
Thanks for the replies.
Hopefully that may sort out both problems
Andy.
dusty123 is offline
post #5 of 11 (permalink) Old 27-01-2015, 19:58
To get the clock out most people take the console out but if you have small handsyou can get get to the screws through the radio appature.
If getting one from the scrap yard look for a Rover 200 or 25 or a MG ZR as they are the same but the screws are hidden behind a pop off cover.
post #6 of 11 (permalink) Old 15-05-2017, 21:30
Regarding fob and key, check on eBay for a replacement set up ( BCU , Ecu, fobs, keys and barrel ) if you have a facelift. I replaced mine a couple of years ago when the BCU died and was fried lol. I purchased a Ecu,BCU 2 fobs and barrel with keys for 70 then just swapped everything over which took 20 mins. I then purchased another complete setup wit 2 fobs for 20 which I tested on my ZS and is now sitting in my cupboard.
As mentioned if you have pre facelift car with square 2 button fob then a second hand fob can be found easily in breakers or eBay and programming is cheap but you need the car with you for this.
As for the clock I would replace it with a Lucas clock from an early model 25,45 or ZR,ZS or rover 200/ 400. I had same fault on my pektron clock, repaired it then it failed in some very cold weather, changed a few pektron which all failed until I put a Lucas clock in few years back no more problems.
Hopefully you get it sorted before you go back, Bren.
Bren10 is offline
post #7 of 11 (permalink) Old 15-05-2017, 21:48
This is another (two and a half year old thread) which has been revived by a newbie with a pointless post. Why do they do that??
Edit: the post referred to has been removed, so this doesn't make much sense anymore
post #8 of 11 (permalink) Old 15-05-2017, 23:28
probably because they own the locksmith link?
dert is offline
post #9 of 11 (permalink) Old 16-05-2017, 21:45
But Bren has been here for several years.
post #10 of 11 (permalink) Old 16-05-2017, 23:27
The post that I had referred to has been removed (illicitly advertising the posters own auto locksmith business), so it is now somewhat out of place.
I wasn't having a go at Bren over anything - I think he had just got drawn into replying by the sudden random post and probably hadn't noticed the age of the thread.
post #11 of 11 (permalink) Old 17-05-2017, 13:31
It was late when I replied so didn't notice the date lol and ad must have been already removed but no worries
Bren10 is offline
Lost key fob - help please peter420 MG ZS / Rover 45 & 400 20 16-09-2011 07:00
Mg zr - lost fob and key, don't have spare fob but have spare key - any advice welcom Johnglasgow82 MG ZR / Rover 25, 200 & Streetwise 7 03-07-2011 15:04
Lost Fob and key hidnmine MG ZS / Rover 45 & 400 8 25-04-2011 20:31
Lost My Key and Key Fob Rover 620 Diesel TraceyI Rover 600 21 18-02-2011 12:34
Lost my zr key and fob DAZ ZR MG ZR / Rover 25, 200 & Streetwise 7 19-05-2010 18:04
