MG ZS Enging struggling to put down power - MG-Rover.org Forums
post #1 of 2 (permalink) Old 18-03-2017, 18:41 Thread Starter
Exclamation MG ZS Enging struggling to put down power
Hi, all, never been on this forum before and I'm not really that car savvy. got a 2005 1.6 MG ZS that is having some engine problems. Driving out and about today in the lower gears it feels like the car is struggling to put any power down on the ground, it will move for a maybe 10 seconds or so and it's like it finds what it's looking for and will move off at the speed its supposed to. This happens in 1st through 3rd ( have had it up to higher gears with this problem thus far ) When the car is idling it feels as if it's searching for the correct rhythm it normally runs at causing the whole car to shudder violently and can sometimes cause the engine to die all together, leaving it for 10 minutes or so and it will turn back over again but not before this time. No dash warning lights come on when this happens and the car has fuel, coolant and oil so anything else is beyond my knowledge.
Anything you guys can to do help would be great!
Cheers in advance
- Si
taits2204 is offline
post #2 of 2 (permalink) Old 18-03-2017, 20:17
Assuming it's been serviced and filters, plugs, oil etc have been changed to schedule, best to get the fault codes checked with a obd2 reader, as it could be many things. If oil and coolant are always stable, the HT circuit would be at the top of my list of possibilities...
enging inspection cover bolts gordongilchrist MGF and MGTF (Sponsored by MGFnTFBITZ) 17 20-08-2014 14:53
18G 1746A - Enging locking pin. eats-1964 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 07-03-2010 19:05
Loss of power/enging "missing" on roundabout DHillary Diesel Forum! 6 23-01-2009 13:04
wheres the hole to put power cable on rover 75? jamiek In-Car Audio, Entertainment, Sat Nav etc... 1 16-07-2008 13:49
Power problems (Help before i put a match to it!!!!) DarrenB MGF and MGTF (Sponsored by MGFnTFBITZ) 11 10-01-2005 17:23
