Mg zs one headlight not working? - MG-Rover.org Forums
post #1 of 6 (permalink) Old 06-03-2017, 15:11 Thread Starter
My dad just got a nice mg zs 1.8 red colour. Pukka car drives like a dream but headlight doesnt work. Changed it but doesnt seem to work. Its passangers side im assuming it doesnr have its own fuse and it shares one with other headlight. If so there must be a break in the wire. If this is the case what is a repair going to cost. If i can find it ill resolder it
If it shares a fuse is there any reason i cant get a while from over from one headlight ti the other.
Ben93 is offline
post #2 of 6 (permalink) Old 06-03-2017, 15:41
Headlamps are fused separately. Not sure which the fuses are, but I am sure someone will advise.
post #3 of 6 (permalink) Old 06-03-2017, 15:59
fuse lay out should be written on a plastic card on top of the pull down tray covering the fuse box. or you could do a quick search for the lay out.
Fusebox diagram anyone?
Andy400 is offline
post #4 of 6 (permalink) Old 06-03-2017, 17:02
Comprehensive fuse layout is made sticky in this section for some time: Rover 400 & 45 / MG ZS: Fuses, Relays, ECUs
post #5 of 6 (permalink) Old 06-03-2017, 20:12
When filament bulbs fail, a brief current surge is common.
With domestic bulbs, it's often enough to trip a circuit breaker. Fuses are generally less sensitive, but if you still have the old bulb, check whether it's blown. If yes, then it almost certainly took the fuse with it. If the old bulb is ok, the fuse may simply have blown due to old age if it was out of spec when new.
Fingers crossed!
jdhturner is offline
post #6 of 6 (permalink) Old 07-03-2017, 00:00
Check dash fuse for headlamp below steering wheel, if the fuse is ok then it's worth removing battery and the battery tray as wiring loom rubs under the tray and earths out. I had this on my daughters mk2 ZS which cause indicator fuse to keep blowing. It's a common fault and worth a look anyway to prevent future problems, I check my mk2 after seeing my daughters and although it hadn't cut through to wire it wasn't far off.
Bren10 is offline
One for the wiring experts - headlight not working t0m4ever MG ZR / Rover 25, 200 & Streetwise 8 18-02-2014 05:50
N/S headlight not working tony777 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 07-10-2010 22:58
Headlight Washers Not Working alexward MG ZT / Rover 75 (Sponsored by Rimmer Bros) 12 14-10-2009 14:47
Headlight/ headlight levellers not working apk1@bigfoot.co MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 09-10-2007 12:42
Headlight washer not working Printer MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 18-09-2006 19:44
