Please help me disable my immobiliser !!!! - MG-Rover.org Forums
post #1 of 6 (permalink) Old 14-01-2007, 21:04 Thread Starter
Unhappy Please help me disable my immobiliser !!!!
Hello everybody.
I would be extremely grateful if you can instruct me how to get over my immobiliser being jammed on permanently. I am disabled, unable to work & have little money, so I cannot afford to get a garage to sort it out for me.
I have a M Reg Rover 414 si 16V. There was a problem with the alarm/immobiliser when I bought the car from a garage a year or so ago. They told me not to use the key fob at all & to lock/unlock the car using the key as there is a fault with a unit in the driver's door. The central locking is not activated by locking the driver's door with the key, so I have to lock the other three doors manually. The alarm does not activate when I lock the car with the key.
This is fine most of the time, but when the temperature is around freezing or below the alarm/immobiliser activate when I lock the car with the key, so I do have to use the keyfob to deactivate the alarm/immobiliser and open the driver's door when this happens.
On Friday night the alarm/immobiliser activated when I locked the driver's door but nothing happened when I tried to unlock the car with the keyfob later. The alarm/immobiliser is stuck on now & I cannot stop the alarm from sounding when I open the driver's door & I cannot start the car of course. I have changed the battery in the keyfob carefully following the instructions in the Rover manual but still no joy. I do not have the security code to unlock the system by turning the key in the driver's door & I only have one keyfob.
I have found 2 possible solutions on the internet:
1) "Hi, I had this same problem with my Rover 414 and after 2 weeks trial and error I found out that if you disconnect the white plug hidden behind the front bumper (below the passenger side light) for about 5mins then that resets the alarm/immobiliser system."
2) "Had exactly the same problem with my L-reg 414 last week. The AA sorted it out by:
1. Open drivers door, open bonnet, wind down drivers window, close drivers door.
2. When the alarm stops, lift the bonnet and disconnect the negative lead from the battery.
3. Connect a power pack to the positive terminal and the engine block.
4. reach in the drivers window, switch on the ignition and leave for 3 minutes.
5. Switch off the ignition, disconnect power pack, re-connect battery.
Bingo ! car starts."
Have you any idea if either of these work please. If 2) above works, do you know what is meant by a "power pack", so I can give it a try?
I would much rather ditch the immobiliser to stop this happening again. So in addition to freeing the immobiliser now, does anyone know how to permanently disconnect the immobiliser?
Any help would be much appreciated as I am stuck at home until I can start my car again.
Best regards,
Matt
totallyuseless is offline
post #2 of 6 (permalink) Old 14-01-2007, 21:23
Get the door key code from the dealer if you don't already have it. This is a four digit number you enter into the drivers door lock that disables the immobiliser until the car is next locked with the fob.
The dealer will want proof of ownership and id before giving you this, some charge but not a lot!
Dont know of any other method....if the immobiliser was easy to get around then there wouldn't be much point in it being there in the first place!
montyturbo is offline
post #3 of 6 (permalink) Old 14-01-2007, 21:38
Agreed - do you have this code or not?
If there is trouble with the OSF CDL unit, it *might* not work........
post #4 of 6 (permalink) Old 14-01-2007, 21:44 Thread Starter
Thank you for replying guys.
No I do not have the unlock code.
When I got the car from a Rover dealer the code was not in the paperwork.
They said they could not get the code for me because the database had been lost. Do you think they were misinforming me?
Best regards,
Matt
post #5 of 6 (permalink) Old 15-01-2007, 00:16
Mmmm....Rover..
technozen's Avatar
The code can be read using diagnostics equipment.
technozen is offline
post #6 of 6 (permalink) Old 15-01-2007, 01:10
Im fairly sure you can still get codes now Matt. About 5 months ago I had the code and 2 spare keys, for my 98 400, from my local rover dealer (Inchcape) after I dropped the keys down a drain! Whoops!
2 Spare keys and the unlock code cost me just 12.50 but I think the price varies between dealers.
###permanently Disable Rover Immobiliser### birchuk MG ZR / Rover 25, 200 & Streetwise 18 07-08-2015 06:26
disable 214 immobiliser with access code but no fob nealhyett Coupe 3 22-04-2008 20:47
Can I disable the alarm and immobiliser? canan Rover 600 4 07-03-2008 09:04
immobiliser disable? VTEC MG ZR / Rover 25, 200 & Streetwise 1 03-07-2006 10:41
Help needed quickly to get my car back - disable immobiliser? ThumpJunkie Others 5 11-11-2005 11:17
