Resistor pack - Replacing with proper valued ceramics. Including pictures! - Page 2 - MG-Rover.org Forums
post #21 of 58 (permalink) Old 27-01-2013, 22:50
Car: MG ZS 180
Send a message via MSN to RicWin
I'll be needing one of these for my ZS.
Matt, are you likely to be at the next Meet? :P
RicWin is offline
post #22 of 58 (permalink) Old 28-01-2013, 00:22 Thread Starter
Car: MG ZT-T+ CDTi Auto
Probably not, but I'm local so can drop one off if needs be.
DMGRS is offline
post #23 of 58 (permalink) Old 28-01-2013, 09:32
Car: MG ZS 120+ & Suzuki TL-1000R
Originally Posted by mattyprice4004 View Post
The answer is pretty simple:
- Speed one is the finest as it's resistance must be the greatest to produce the lowest fan speed. This fails the most.
- Speed two a bit thicker as it's resistance is a little less for a middling speed. This fails for the same reason as #1, however tends to last a bit longer.
- Speed 3 rarely fails as it's heavy gauge wire and doesn't have to drop a lot of power as heat. Still, I include it as I'd rather all 3 were changed.
It's not just the resistance causing failure of the slower speeds more frequently. The airflow passing through the fan is used to cool the resistors. The slower fan speeds dissipate more heat, but because the fan's going slower they actually get less airflow to cool them down as well.
I only started getting problems with my OEM resistors when I used slow fan speeds on high heat settings. Probably not a co-incidence...
warwickswinger is offline
post #24 of 58 (permalink) Old 28-01-2013, 15:03 Thread Starter
A very valid point - I overlooked that. Less airflow definitely won't help the issue!
DMGRS is offline
post #25 of 58 (permalink) Old 28-01-2013, 15:31
Does it work for MG TF?
Hi, will this work with an MG TF?
brionymarples is offline
post #26 of 58 (permalink) Old 28-01-2013, 17:46
Car: 25 2.0 IL Turbo Diesel
My 25s fan has been playing up for a while, the fan will only sometimes work on speed 4, if you give the housing of the fan a "tap" it comes back on, and the fan speed seems to change, took it to a rover garage near me and he said it has the resistor mod done and its dangerous so he's disconnected it, said it needs a new fan now as the mod has melted the fan assembly.
Then he quoted me 450 to replace it, if I buy a new assembly and resistor pack from ebay etc will this sort the problem or could it be a wiring issue?
Rick420Di is offline
post #27 of 58 (permalink) Old 28-01-2013, 19:03 Thread Starter
Hi there, yes it will. Have sold a fair few to TF owners.
I think it's just a duff fan in all honesty - unless someone's fitted resistors wrong there's not much that could do any damage.
Second hand fan and a resistor pack and you'll be sorted.
DMGRS is offline
post #28 of 58 (permalink) Old 28-01-2013, 21:50
Cheers Matty, will get one from scrappys near me at the weekend and see what happens
Think I should have let him fix it for me? 450 sounds like a bargain!
post #29 of 58 (permalink) Old 29-01-2013, 00:19 Thread Starter
450 to do the work? You can do it for a tenth of that!
Blower: http://www.ebay.co.uk/itm/ROVER-200-...item3f1f74a270
And you'll just need one of my resistor packs, or you can send me your pack for repair.
Changing is pretty easy, too.
Note: The fan above is for a 25, as per your information. You'll find one for a 400 at a similar price.
20 for the parts, 5 for beer and 425 to spend on important stuff.
DMGRS is offline
post #30 of 58 (permalink) Old 29-01-2013, 12:29
Car: Rover 25, 2002, 1.4 petrol, 3-door
Hi there - I bought a 2002 Rover 25 before Christmas. At first only the 3 & 4 heating worked, then they packed up as well. Mechanic put in a new 'resistor' - but again, the heater seems to work sporadically. Does that mean the motor has gone?
The car only has 42000+ miles.
Any advice welcome
Kiki (female, old but not too dumb, new to Rover, new to English weather)
Kikibluegirl is offline
post #31 of 58 (permalink) Old 29-01-2013, 19:06
Car: Rover 600
Hiya mate, Im in need of the ceramic heater resistors for my Rover 45, and wondered if you had any left? Can you let me know (if youve got any) what the procedure is?
Chris
chrisbill1959 is offline
post #32 of 58 (permalink) Old 31-01-2013, 11:45 Thread Starter
Any advice welcome
It sounds like the fan blower is knackered, you can pick one up from eBay for about 15. Have a search for 'Rover 25 blower'.
Chris
I have indeed, simply send the amount in my signature for a Heater Resistor Repair pack to the PayPal address at the bottom of my signature.
Make sure you include your full address within the PayPal notes.
DMGRS is offline
post #33 of 58 (permalink) Old 13-02-2013, 21:16
Car: zs 180 v6
mine has gone on my zs on 1 and two is there anything i have to do or do u just swap them over cheers matty as waant to get it done
ozzyd79 is offline
post #34 of 58 (permalink) Old 14-02-2013, 11:39
Car: MG ZS facelift
If you cover postage I'll also more than happily fit them for you to your existing pack.
is this offer still going as im cr#* with a soldering iron
hellkef is offline
post #35 of 58 (permalink) Old 14-02-2013, 12:06 Thread Starter
Just swap them over - snip the old resistors off and solder the new ones in place. Full instructions provided.
I can indeed still repair existing packs - send the pack to me and I'll sort it out.
I'll do the replacement including Recorded delivery postage back to you for 7.99.
DMGRS is offline
post #36 of 58 (permalink) Old 14-02-2013, 22:48
Car: MG ZS facelift
will pop down the scrap yard get a spare one atleast then i'll be able to still use one
hellkef is offline
post #37 of 58 (permalink) Old 20-02-2013, 13:34
[QUOTE=mattyprice4004;5327892]It sounds like the fan blower is knackered, you can pick one up from eBay for about 15. Have a search for 'Rover 25 blower'.
Thanks Matty.
Kiki
post #38 of 58 (permalink) Old 20-02-2013, 14:37 Thread Starter
You can still use speed 4 with no pack fitted.
DMGRS is offline
post #39 of 58 (permalink) Old 20-02-2013, 14:43 Thread Starter
[QUOTE=Kikibluegirl;5350756]
Thanks Matty.
Kiki
No worries at all.
DMGRS is offline
post #40 of 58 (permalink) Old 16-03-2013, 13:29
So I've tried to get the old fan out but I seem to be having trouble. Any idea how they come out. Does the fan come out on its own? There doesn't seem to be enough room under it to get it out
Where's the resistor pack? rov618i Rover 600 4 08-11-2010 20:16
Resistor pack RudeDogg1 MG ZS / Rover 45 & 400 2 26-08-2007 21:02
resistor pack (Heater) bhogalb MG ZR / Rover 25, 200 & Streetwise 13 20-03-2007 00:25
Resistor Pack Soupdragon Others 21 25-12-2004 02:07
