Resistor pack - Replacing with proper valued ceramics. Including pictures! - Page 3 - MG-Rover.org Forums
post #41 of 58 (permalink) Old 16-03-2013, 13:38
Car: Rover 45 1.8 Impression
Another plus here for matty...pack arrived packaged well, fitted it easy and fan speeds all working...thanks matty
Keejteej is offline
post #42 of 58 (permalink) Old 16-03-2013, 13:51
Car: 45 2.0 Diesel
Originally Posted by Rick420Di View Post
So I've tried to get the old fan out but I seem to be having trouble. Any idea how they come out. Does the fan come out on its own? There doesn't seem to be enough room under it to get it out
Yeah just undo the 3 screws and give it a jiggle, it drops out. I take mine out once a year or so to remove any dead leaves and crud.
Sent from my ARCHOS 80 COBALT using Tapatalk HD
Chrisund123 is offline
post #43 of 58 (permalink) Old 16-03-2013, 14:04
Car: 25 2.0 IL Turbo Diesel
Talking
3 screws? Aah only removed 2!
Rick420Di is offline
post #44 of 58 (permalink) Old 19-03-2013, 20:07
Cant seem to get it to come out very easily, wonder if its the same on a 25?
Wonder whether I should start my own thread on this one with pics?
post #45 of 58 (permalink) Old 20-03-2013, 12:50
Hi, Apologies for hijacking your thread, however have looked all over and it appears you're a bit of an expert on this. My heater pack failed last year and I replaced it with resistors from Maplins as per your info. However they have stopped working again and after replacing them the fan still only works on 4. Is there anything else that can cause this problem or have I just made an arse of replacing the resistors?
cie_barone is offline
post #46 of 58 (permalink) Old 06-04-2013, 06:57
hi,re your resister pack will it fit in a mg tf 2004? as ive just bought one ane the heater doesnt blow on settings one and two.
maNYY THANKS
spuddy333 is offline
post #47 of 58 (permalink) Old 22-04-2013, 11:18
Car: MK2 ZS TD
What are the speeds like on these?
I bought one off ebay and it seems the speeds are all over the place, 1 barely does anything 2 is about what id expect 1 to be 3 is a bit faster and 4 is what id expect 3 to be, 4 isnt even that fast, its crap
Chaz is offline
post #48 of 58 (permalink) Old 23-09-2013, 12:48
Car: 04 TF 135
Are you still doing the solder / post back service? Mine has gone kaput
bensewell is offline
post #49 of 58 (permalink) Old 23-09-2013, 13:35 Thread Starter
Car: MG ZT-T+ CDTi Auto
DMGRS is offline
post #50 of 58 (permalink) Old 23-09-2013, 16:53
Car: 04 TF 135
Ordered cheeeeeers
post #51 of 58 (permalink) Old 24-09-2013, 07:08
Car: 04 TF 135
Originally Posted by mattyprice4004 View Post
So ordered this, what do I need to do now? send mine back to you? or are you sending me some nice bits to solder? Don't mind any either way...
post #52 of 58 (permalink) Old 06-12-2013, 19:51
Car: Rover 45 Impression S3 TDie
Hi
Are you able to help?
Unfortunately your instruction sheet is not clear and the photos very faded.
I received the 3 resistors labelled 1, 2 and 3.
I have soldered Resistor 1 to the M1 and M2 connectors - seems to test ok with multimeter.
I have soldered Resistor 2 to the Lo and M1 connectors (legs were supplied separated so I assumed that it followed a pattern like the old resistor wire versions) - tested with multimeter.
I have soldered Resistor 3 to the Hi connector only as it was supplied with both legs twisted together and bound with some copper wire. I removed the copper wire and untwisted the wire as it seemed to make it easier to solder it.
Upon fitting in the car I have no fan until speed 4.
Must be something wrong?
Neil :-(
Neil_C_Rover25 is offline
post #53 of 58 (permalink) Old 12-12-2013, 18:47
Solved it and now working.
Excellent product.
post #54 of 58 (permalink) Old 11-03-2017, 15:22
Car: MG ZR Stepspeed
Another shoutout for Mat at dmgrs. Got the pack and fitted today. Works great.
Springle
Springle is offline
post #55 of 58 (permalink) Old 11-03-2017, 21:05
6KH
Car: Rover 45, MG ZR 2.0TD, MG ZS 180, MG ZT 260
I've used a Rezpax set in both my 45 and ZS. In the 45 the set has run for 150,000 miles.
rezpax.com - Home
These are the same wire coils configuration as the originals, but made from a non-oxidising wire that doesn't burn out. It's an option.
Andrew
6KH is offline
post #56 of 58 (permalink) Old 15-03-2017, 00:19
For 5.50 it would just be downright rude to not sort this NOW instead of waiting for the inevitable!
Mat`s done it AGAIN!
Pilzy is offline
post #57 of 58 (permalink) Old 15-03-2017, 09:19
For anyone needing some more help fitting and soldering up, here's my fix it video:
Pilzy likes this.
comeinhandy is offline
post #58 of 58 (permalink) Old 15-03-2017, 09:49
Excellent as ever Comeinhandy.
You seem to be amongst the only MG how to video maker that there is.
As I said before on one of your YouTube vids, I wish you were my next door neighbour!!!
Keep up the GREAT work, it is truly appreciated!
Pilzy is offline
Where's the resistor pack? rov618i Rover 600 4 08-11-2010 20:16
Resistor pack RudeDogg1 MG ZS / Rover 45 & 400 2 26-08-2007 21:02
resistor pack (Heater) bhogalb MG ZR / Rover 25, 200 & Streetwise 13 20-03-2007 00:25
Resistor Pack Soupdragon Others 21 25-12-2004 02:07
