Rover 400 & 45 / MG ZS: Fuses, Relays, ECUs - MG-Rover.org Forums
post #1 of 4 (permalink) Old 06-04-2016, 21:27 Thread Starter
Post Rover 400 & 45 / MG ZS: Fuses, Relays, ECUs
-- 1995 -- Rover 400
-- 2000 -- Rover 45 / MG ZS mk1
-- 2004 -- Rover 45 / MG ZS mk2
post #2 of 4 (permalink) Old 06-04-2016, 21:28 Thread Starter
Rover 400
ECU locations
1. Window lift ECU (in the drivers door)
2. Multi Function Unit (MFU) - below steering wheel
3. PGM-Fi ECU - 416 Automatic only
4. SRS ECU (behind centre console)
5. Anti-theft alarm ECU & central door locking ECU (behind centre concole)
6. MEMS 1.9 (except 416 Automatic) or BOSCH ECU (in case of some Diesel)
7. ABS ECU - 416 Automatic
8. ABS ECU - except 416 Automatic
Relay locations
- In engine compartment
01. Main relay module --- to VIN WD274935 - YWB100710
----------------------- from VIN WD274936 - YWB100970
02. A/C relay module - YWB100800/1
03. Main relay - YWB100560/790 (Diesel engine only)
04. Starter relay - YWB100560/790 (Diesel engine only)
NOTE:-- to VIN WD274935 - YWB100560
------from VIN WD274936 - YWB100790
- Behined centre console
05. Rear wiper relay - YWB10032 - RH side
06. Power wash relay - YWB10027 - RH side
07. Front Fog Lamp Relay - YWB10027 - RH side
08. Cruise Relay - SCB100140 - RH side
09. Daylight Running Lights Relay - YWB10032 - RH side
10. Starter relay - YWB100630 - (416 Automatic only) - LH side
- Behined RH side of facia
11. Main relay module - YWB100590 (416 Automatic only)
12. Passanger seat relay box - YWB10050
13. Drivers seat relay box - YWB10050
- Roof
14. Sunroof relay 1 - YWB10032
15. Sunroof relay 2 - YWB10032
Honda engine 1600 Automatic gearbox ABS fusebox
Engine compartment fusebox
- Relays
1. Cooling Fan Relay (non aircon) - YWB10027
2. Heater/Blower Motor Relay - YWB10027
3. HRW Relay - YWB10027
-Fuse--Rating---Function
--A----80 amp---Main fuse
--B----50 amp---Column switch, feeds fuses 19 and 20 in the passenger compartment fuse box
--C----50 amp---Ignition switch
--D----40 amp---Air conditioner
--E----30 amp---Blower motor
--F----50 amp---Window lift,feeds fuses 1, 3, 6 and 11 in the passenger compartment fuse box
--G----30 amp---Relay module (air conditioning)
--H----15 amp---MEMS relay and inertia switch
--J----7.5 amp--ICE/clock
--K----30 amp---Cooling fans/air con
--L----30 amp---Heated rear window
--M----20 amp---MFU/hand brake/horns
--N----10 amp---Hazard indicator
Passenger compartment fusebox
- Relays (R)
1. Window lift Relay - YWB10027
2. Flasher Relay - YWT10003
--1----30 amp---Sunroof (relays 1 & 2)
--2----20 amp---Heated seats
--3----7.5 amp--Taildoor/Interior lamp
--4----20 amp---RH rear window switch
--5----20 amp---Window control unit/driver’s window switch
--6----20 amp---Alarm ECU
--7----20 amp---LH rear window switch
--8----20 amp---Passenger window switch
--9----10 amp---RH headlamp
-10----10 amp---LH headlamp/main beam warning light
-11----15 amp---Front fog lamp relay
-12-------------not used
-13----7.5 amp--Fresh air circulation/mirror switch/air conditioning
-14----20 amp---Rear wiper motor/Sunroof relays
-15----10 amp---Dim dip (up to 97.5 MY)
----------------MFU/alarm/instruments/reverse lamps/hazard/amps/twin airbag
-16----10 amp---ABS modulator
-17----10 amp---Dim dip resistor (RHD only) up to 97.5 MY
-18----7.5 amp--Multi-function relay unit (starter relay for Rover ECM)
-19----10 amp---RH rear lamp/side, number plate light and illumination
-20----7.5 amp--Multi-function unit
-21----10 amp---RH headlamp (dipped)
-22----10 amp---LH headlamp (dipped)
-23----15 amp---Cigar lighter/radio/clock
-24----15 amp---MEMS/Instruments/speed sensor/relays
----------------Fuel pump (416 Honda Automatic)
-25-----3 amp---SRS (twin)
-26----15 amp---Engine
-27----15 amp---Ignition coil (416 Honda Automatic)
post #3 of 4 (permalink) Old 06-04-2016, 21:32 Thread Starter
ECU locations
1. Window lift ECU (behind driver's door trim panel)
3. Cruise control ECU - SCB100190 (behind centre console RH side)
4. SRS ECU (in rear of centre console)
5. Anti-theft alarm ECU & central door locking ECU (behind front of centre console)
6. MEMS 3 engine ECU
7. ABS ECU (rear of engine compartment - bulkhead - on passenger's side)
8. Electronic automatic transmission (base of passenger's "A" post)
Relay locations
1. Starter relay (base of LH "A" post) - YWB100560/790
2. Glow plug relay (Front LH side of engine compartment) - L-series engine
----w/o intercooler (TCieM) - YWB100700
----w/ intercooler (TCie) --- YWB100560/790
- Behined centre console - RH side
3. Rear wiper relay - YWB10032
4. Horn relay - YWB10027
5. Reverse relay - YWB10027
- Roof
7. Sunroof relay 1 - YWB10032
8. Sunroof relay 2 - YWB10032
9. Cooling fan relay - behind LH side of front bumper - YWB101220
Relays (R)
1. Not fitted.
2. Heated Rear Window (HRW) relay.
3. Fuel pump relay.
4. Main relay.
5. Blower motor relay.
6. Front fog lamp relay.
7. A/C compressor clutch relay.
--Link--Rating--Vehicle--Function--
---FL1--150 A-----All----Alternator.
---FL2---80 A-----All----Window lift relay, fuse 1, fuse 2, fuse 3, fuse 6, and fuse 11 of the
-------------------------passenger compartment fuse box.
---FL3---50 A-----All----Ignition switch, fuse 27 of the passenger compartment satellite fuse box.
---FL4---80 A--L Series--Cooling fan relay.
--------------& K Series-
---FL4---80 A-----KV6----Cooling fan control unit.
---FL5-------------------Not fitted
---FL6--100 A--L Series--Glow plug relay.
---FL7---40 A-----All----HRW relay.
---FL8---50 A-----All----ABS ECU.
---FL9---50 A-----All----Lighting switch, fuse 20 of the passenger compartment fuse box.
--FL10---40 A-----All----Blower relay.
--FL11---50 A---A/C------Condenser fan.
--------------vehicles---
----------------only-----
--FL12---50 A-----All----Starter relay.
--Fuse--Rating--Vehicle--Function--
---F1----15 A--L Series--Alternator, speed transducer, ECM, Clutch pedal position switch.
---F1----15 A--K Series--Speed transducer, gearbox secondary speed sensor, HO2S.
---F1----15 A----KV6-----Butterfly valve, balance valve, CKP sensor, purge control valve, HO2S.
---F2----20 A--K Series--Gearbox Interface Unit (GIU), Automatic transmission selector.
---F2----20 A----KV6-----Automatic transmission selector, automatic transmission ECU, GIU.
---F3----15 A--L Series--Glow plug relay, MAF sensor, EGR solenoid, fuel pump.
---F3----15 A--K Series--HO2S, purge control valve, CMP sensor.
---F3----15 A----KV6-----HO2S, CMP sensor.
---F4----10 A--L Series--Compressor clutch relay, cooling fan relay.
---F4----10 A----KV6-----Compressor clutch relay, condenser fan control unit, cooling fan control
-------------------------unit.
---F5----10 A----All-----MFU, brake pedal switch, horn relay.
---F6----15 A----All-----Front fog lamp relay.
---F7----15 A----All-----Hazard warning switch, instrument pack.
---F8----15 A----All-----Radio/cassette player, radio/CD player, radio remote display, clock.
---F9----10 A----All-----Compressor clutch relay.
--F10----20 A----All-----Inertia switch, fuel pump relay.
Pasanger compartment fusebox
---F1----30 A-----All----Sunroof open relay, sunroof close relay.
---F2----20 A-----All----RH heated seat relay, LH heated seat relay.
---F3---7.5 A-----All----Luggage compartment interior lamp, passenger compartment interior lamp,
-------------------------diagnostic socket, folding door mirror ECU.
---F4----20 A-----All----Door mounted RH rear window switch, console mounted RH window switch.
---F5----20 A-----All----Window lift ECU, console mounted RH front window switch.
---F6----20 A-----All----Anti-theft alarm ECU, instrument pack.
---F7----20 A-----All----Door mounted LH rear window switch, console mounted RH window switch,
-------------------------sunroof open relay, sunroof close relay.
---F8----20 A-----All----Console mounted LH window switch.
---F9----10 A-----All----RH headlamp.
--F10----10 A-----All----LH headlamp, instrument pack.
--F11----20 A--K Series--ECM.
----------------& KV6----
--F12----15 A--L Series--ECM, alternator, instrument pack.
--F12----15 A----KV6-----ECM, alternator, instrument pack, cruise control relay, cruise control
-------------------------switch.
--F13----15 A-----All----Mirror switch, driver door mirror, passenger door mirror, A/C switch pack,
-------------------------fresh/recirculated air motor, fresh/re-circulated air switch, RH seat
-------------------------heater, LH seat heater, folding mirror ECU, rear wiper motor.
--F14--------------------Not used.
--F15----10 A-----All----Headlamp levelling switch, seat belt switch, MFU, reverse lamp switch, CVT
-------------------------switch, reverse lamp relay, anti-theft alarm ECU, instrument pack, hazard
-------------------------warning switch.
--F16----10 A-----All----ABS ECU.
--F17----10 A-----LHD----LH tail lamp.
--F18---7.5 A-----All----Starter relay.
--F19----10 A-----All----RH tail lamp, LH tail lamp (RHD only), RH rear number plate lamp, LH rear
-------------------------number plate lamp, RH headlamp, LH headlamp, MFU, sport/snow switch, fog
-------------------------lamp switch, glove box lamp, HRW switch, radio/cassette player, radio/CD
-------------------------player, cigar lighter illumination, heater control illumination.
--F20---7.5 A-----All----MFU.
--F21----10 A-----All----RH headlamp.
--F22----10 A-----All----LH headlamp.
--F23----15 A-----All----Radio/cassette player, cigar lighter, remote display/clock, radio/CD player,
-------------------------audio system interface unit.
Pasanger compartment sattelite fusebox (fuse holders)
--F25-----3 A-----All----SRS DCU.
--F26----20 A-----All----Power wash relay.
--F27----20 A-----All----Rear wiper relay, windscreen wash/wipe switch.
post #4 of 4 (permalink) Old 06-04-2016, 21:33 Thread Starter
ECU locations
01. Cruise control ECU - SCB100190 (behind centre console RH side)
02. Anti-theft alarm ECU & central door locking ECU (behind front of centre console)
03. MEMS 3 engine ECU
04. SRS ECU (in rear of centre console)
05. ABS ECU (rear of engine compartment - bulkhead - on passenger's side)
06. Puls width ECU (passenger "A" post)
07. Air temperature Control (ATC) ECU (behind centre console)
08. Electronic automatic transmission (base of passenger's "A" post)
09. Park distance control (Behind carpet - luggage compartment - RH side)
10. Mirror Folding ECU (behind pasanger door trim panel)
Relay locations
01. Cruise control relay - base of passenger 'A' post - YWB10027
02. Cooling fan relay - behind LH side of front bumper - YWB101220
03. Blower recirculation relay - behined centre of front console - YWB10032
04. Air conditioning relay - behined centre of front console - YWB10027
05. Boot release relay - behined centre of front console - YWB10027
06. Reverse relay - beside passenger compartment fusebox RH side - YWB10027
07. Horn relay - beside passenger compartment fusebox RH side - YWB10027
08. Glow plug relay (Front LH side of engine compartment) - L-series engine
- Roof
09. Sunroof relay 1 - YWB10032
10. Sunroof relay 2 - YWB10032
Relays (R)
1. Not fitted.
3. Fuel pump relay.
4. Main relay.
---FL2---80 A-----All----Feeds fuse 1, fuse 3, fuse 5, fuse 7, and fuse 9 of the
---FL3---50 A-----All----Feeds fuse 18 of the passenger compartment fuse box.
---FL9---50 A-----All----Feeds fuse 17 of the passenger compartment fuse box.
--Fuse--Rating--Function--
---F1----20 A---SCU, BBUS, Alarm LED.
---F2----20 A---Window Lift Rear RH.
---F3----15 A---ECM
---F4----20 A---Window Lift Rear LH.
---F5----10 A---Interior Lamps, Boot Lamp, Diagnostic Socket.
---F6----20 A---Window Lift Passenger, Sunroof Relay Coils.
---F7----30 A---Sunroof.
---F8----20 A---Window lift driver.
---F9----20 A---Seat heat.
--F10----10 A---Headlamp main beam RH
--F11----10 A---Front Side-lights RH, Tail Lamp RH, No. Plate Lamp.
--F12----10 A---Headlamp Mainbeam LH.
--F13----10 A---Front Side-lights LH, Tail Lamp LH, Interior Illumination (Non Scand).
--F14----10 A---Headlamp dip RH.
--F15----10 A---DRL Interior illumination (Scand)
--F16----10 A---Headlamp dip LH
--F17----10 A---SCU, W/Lift Relay Coil
--F18----20 A---Power Wash.
--F19----15 A---Clock, Cigar Lighter, Radio.
--F20----10 A---Crank relay coil.
--F21----20 A---Wash/Wipe (Fr & Rr), Headlamp level motors.
--F22----Spare.
--F23----15 A---ECM, ACG, Cruise Relay & Switch, No-charge warning light.
--F24----10 A---ABS ECU.
--F25----10 A---SCU, Rev. Lamps, Auto Selector Lamp, Headlamp level Sw, IPK.
--F26----15 A---Rear Wiper Motor, Mirrors, Seat heat Relays, Blower Relay Coil, A/C Sw Pack, DRL
----------------(Scand), Recirc Motor, ATC.
--F27-----5 A---SRS DCU.
Rover 200 & 25 / MG ZR / SW: Fuses, Relays, ECUs Roverlike MG ZR / Rover 25, 200 & Streetwise 7 19-03-2016 10:51
mk2 mgf fuses and relays help MGF MARK MGF and MGTF (Sponsored by MGFnTFBITZ) 3 12-12-2010 19:49
Some ZR/200 stuff - Relays,fuses,lights,springs,parcel shelf... MG ZR 105 For Sale 10 30-11-2009 23:19
electrics, fuses and relays... roobs MGF and MGTF (Sponsored by MGFnTFBITZ) 2 30-11-2008 07:16
Help Please for rover 200 Fuses, electrics arbuckle MG ZR / Rover 25, 200 & Streetwise 18 19-01-2007 21:13
