Is this a Rover 416 AUTO gearbox? - MG-Rover.org Forums
post #1 of 26 (permalink) Old 07-01-2011, 10:08 Thread Starter
Car: Rover 416IXL, Saxo VTR
Hi all, I while ago I purchased this gearbox from ebay: http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
Was meant to be having it fitted today along with a new clutch, however when I opened up the wrapping that the gearbox was in today it looks to be a different gearbox to the R65 fitted to my 414! The bloke told me its off of a V reg 416 with around 80k miles on the clock.....he diddnt say it was manual or auto, he said the car had HGF so they were breaking it - so was sure it would have been a k series version with R65! However despite the HGF the gearbox must be from the Honda engined auto box one???
Damn.
Rover_King is offline
post #2 of 26 (permalink) Old 07-01-2011, 13:54
for some reason i cant open the link could it be a pg1 box?
adam5172 is offline
post #3 of 26 (permalink) Old 07-01-2011, 15:09
Car: Rover 75 Tourer
Link not working , just type 160450638326 in ebay and you can see the pics.
Not the best quality pic, but the seller did say Manual in the description..
5 SPEED MANUAL GEARBOX
hydraulic clutch type
REMOVED FROM V REG
ROVER 416
IN VERY GOOD WORKING ORDER
Maybe a later type?
RoverSRus is offline
post #4 of 26 (permalink) Old 07-01-2011, 16:57
If it has provision for a clutch it's not going to be an auto, and it clearly has linkages for the gear selector, an auto has a cable.
MikeRJ is offline
post #5 of 26 (permalink) Old 07-01-2011, 17:13
Car: 45 Diesel saloon
If it was from a 416 auto you'd have a major headache and likely the car wouldn't have died due to HGF as the auto was the last of the Rhondas so a hondamatic!
gazza487 is offline
post #6 of 26 (permalink) Old 07-01-2011, 17:40 Thread Starter
*LINK NOW AMENDED*
It does say manual in the description, it just looks completely different. It doesnt have the circular black plastic cap (breather thing) on top, the linkage thing looks totally different, and the starter motor hole looks to be in the wrong place - still at the front, but higher up.
post #7 of 26 (permalink) Old 07-01-2011, 17:41
looks like it could be a honda box, you got any more pictures of it?
steely is offline
post #8 of 26 (permalink) Old 07-01-2011, 17:43 Thread Starter
Havnt got any pictures at the moment but will take some pictures later when I pick the car up. (I left it outside the garage)
post #9 of 26 (permalink) Old 07-01-2011, 17:57 Thread Starter
Does anyone else have any pictures or diagrames of other Rover gearboxes?
One thing to add....is it has two little tube/pipes going through the casing of the gearbox to the release bearing/centre part (which has a spring on for some reason) which I think is for the fluid. There is NO clutch lever/arm with a fork type piece to move the release bearing.
post #10 of 26 (permalink) Old 07-01-2011, 18:21
do a search on ebay for honda gearboxes, should get a few pictures to compare
steely is offline
post #11 of 26 (permalink) Old 07-01-2011, 18:21
Best bet is to type Rover 400 /45 etc gearbox and Honda Gearboxes, in Google and choose Images tab...
Then compare the pictures to the gearbox you have, what you described is what Im used to seeing, the circular cap etc..all my Rovers so far have had this on gearbox.
post #12 of 26 (permalink) Old 10-01-2011, 16:01 Thread Starter
Just taken some pictures of the gearbox....
Hopefully someone can identify it!?.....
post #13 of 26 (permalink) Old 10-01-2011, 16:24
Any stamps or markings on the casing? It doesn't look like the honda twin cam gearbox.
Doesn't look like an R65 either.
If my money was going on anything it would be from a Rover 75.
empsburna is offline
post #14 of 26 (permalink) Old 10-01-2011, 16:25
Looking at that mount then I think it may well be.
post #15 of 26 (permalink) Old 10-01-2011, 19:00
Would agree its likley to be a 75 gearbox
The two pipes coming out would have been for the hydraulic slave cylinder/thrust bearing (all in one unit)which has been removed and thats why there is no clutch arm and fork on this gearbox
pernix is offline
post #16 of 26 (permalink) Old 11-01-2011, 10:07
Car: Rover 45 Impression L Series
That is definately a Getrag 283 manual box out of a 75.
It should have a label on it somewhere like the attached image.
XPart02 is offline
post #17 of 26 (permalink) Old 12-01-2011, 11:21 Thread Starter
Just had a look and it appears the label has been removed/fallen off at some stage. Can see the paper backing of where a label used to be.
Have had a look at Rover 75 gearboxes on ebay though and I agree with you, deffinatly a getrag Rover 75 box.
Will it fit any 75? I think its an early type judging by the looks of some on ebay, the later ones after around 2003 look to have a slightly different gear linkage part etc.
Dont know what to do with this now, can sell it on on ebay, but I dont know what 75's it will fit, and also if the seller has simply got this box mixed up with a 416 box then I also dont know the mileage, age, or condition of it.
post #18 of 26 (permalink) Old 12-01-2011, 11:23
Have you contacted the seller?
post #19 of 26 (permalink) Old 12-01-2011, 11:31 Thread Starter
I contacted him the other day (when I made this thread) asking him what car it was from as it is differant and wont fit....I asked if it was from a 416 auto. Wasnt rude or anything. Hasnt replied.
post #20 of 26 (permalink) Old 12-01-2011, 13:11
From that linkage assy I would say it is from a V6.
The diesel and 1.8 use a different linkage.
see attached
XPart02 is offline
rover 416 sli auto 1998 robthedarter MG ZS / Rover 45 & 400 1 25-03-2008 00:18
rover 416 sli auto 1998 robthedarter MG ZS / Rover 45 & 400 2 18-03-2008 20:41
Rover 416 gearbox patrover MG ZS / Rover 45 & 400 9 06-03-2008 15:17
Rover 416 SLI AUTO / Leather Stephen G MG ZS / Rover 45 & 400 3 17-07-2007 17:13
rover 416 sli auto whisky chaser Others 1 06-03-2004 08:13
