rover 416 immobiliser problem - MG-Rover.org Forums
post #1 of 5 (permalink) Old 20-01-2008, 19:58 Thread Starter
hi i have a rover 416i n reg.today i disconnected battery and immobiliser has dis armed i have put the code in via the key and lock eg,,,turn to lock then turn left x amount of times then turn right x amount of times ...etc,,as it says in hand book but still i have no joy i go to start the car up and it just makes a sound like the lights have been left on it wont even try to turn over also the led light on doors stays solid on when door is open . i have tried jump starting it but this makes the alarm sound it also makes like a machine gun sound sometimes after in putting the code/????. please if anyone knows how to solve this problem please reply... p.s i have no key fob only keys but have all security codes i cannot understand why it is doing this...
lauranorth19 is offline
post #2 of 5 (permalink) Old 22-01-2008, 23:15
The immob needs the key fob to dissarm
Martin kerr is offline
post #3 of 5 (permalink) Old 22-01-2008, 23:52
Tad
either you don't have the right code or you're not entering it correctly.
look at the little red light on the door when you open the door. if it stays on then the immobilizer is ON.
the directions on how to input the code stated in the manual are incomplete, do the following :
1. make sure all the windows, doors, bonnet and boot are shut tight.
2. lock your car with the key then remove the key, wait till the red light blinks at a slow rate.
3. insert the key and start inputing the code starting by the right direction.
4. remove the key and open the door. if the red light is on, shut the door and start all over again. if there's no red light then you disabled the immoblizer and can now start the car.
Tad is offline
post #4 of 5 (permalink) Old 23-01-2008, 11:02
Car: X-type jag (sorry).
access code.
Hi, some early rovers were given wrong codes. Try adding a 1 to second and fourth digit. So 1,2,3,4 would become 1,3,3,5.
The " machine gun" noise is the cdl motor overheating.
Hope this helps, Cheers
Vic
hood117 is offline
post #5 of 5 (permalink) Old 13-02-2008, 15:06
Just to let everyone know, the above advice did work.
I asked Laura to put a post to this effect but She oviously hasn`t the time!
Cheers,
Vic
hood117 is offline
Rover 416 1996 - Immobiliser? matthew76 'R8' Rovers (aka Wedges!!) 8 01-06-2009 13:30
Rover 416 SLi Immobiliser Problem tombur1463 MG ZS / Rover 45 & 400 0 09-03-2007 13:10
1998 416 Immobiliser problem printmeister MG ZS / Rover 45 & 400 30 11-05-2006 09:30
416 Si (N reg) immobiliser/ECU problem? BenW Others 7 12-08-2005 10:07
1995 rover 416 immobiliser kams1 Others 7 14-03-2005 10:36
