Rover 45 1.8 automatic - noise (from gearbox?) - MG-Rover.org Forums
post #1 of 6 (permalink) Old 17-08-2010, 21:48 Thread Starter
Unhappy Rover 45 1.8 automatic - noise (from gearbox?)
Hi guys,
my 03 reg Rover 45 (53k miles) developed a whirring noise last week and I fear it has to do with the EM6 CVT auto gearbox as the volume of the noise pretty much aligns to the engine RPM.
When I roll down a hill and go into neutral it seems to realign itself with the speed instead of the RPM.
If I rev up in neutral while standing the noise isn't there.
I've checked the gearbox oil and it is plenty, rosy and clean. I hope that's a good sign.
I've made a small video so you can hear a sample of the noise and see how it aligns with the RPM and the gear change. The video quality is ****e so that the file does not become too big. It's 10MB. You can find it here:
http://www.mediafire.com/?oade39mg1hyhnuc
I hope someone can help me. I don't want my beloved Rover to die yet!
Cheers,
Phil
phihe is offline
post #2 of 6 (permalink) Old 18-08-2010, 19:35
Car: Mazda 3 1.6 TS 2006
It may be the bearing inside the box, when they start going, the whine described can be exhibited.
Brains is offline
post #3 of 6 (permalink) Old 18-08-2010, 22:20 Thread Starter
If it was the bearing, what would it take to repair it?
Does it have to repaired or is it just an annoying thing that won't lead to a total failure of the gearbox?
Cheers,
Phil
phihe is offline
post #4 of 6 (permalink) Old 18-08-2010, 22:47
if the bearing goes, it can seize the shaft inside, however the bearing can be done with the box in the car still. just needs the right person to do it. where are u located?
Brains is offline
post #5 of 6 (permalink) Old 19-08-2010, 10:46 Thread Starter
I am in Bristol.
Does anyone know someone who could do a repair like this around here?
I'd be willing to drive a bit...
phihe is offline
post #6 of 6 (permalink) Old 17-06-2015, 13:15
Smile Cheap solution found in North East
Easi gears in Thornaby replaced the bearing in one day for £350 + VAT. I had a previous quote of £1500 and they wanted to send the gearbox to Brighton
gleble is offline
Rover 45 automatic gearbox problems Gunnar MG ZS / Rover 45 & 400 5 19-08-2013 17:14
automatic gearbox problem rover 45 Stroops MG ZS / Rover 45 & 400 1 15-08-2009 21:36
automatic gearbox noise >>CHOP<< MG ZR / Rover 25, 200 & Streetwise 2 08-07-2009 17:53
Problems with automatic gearbox of Rover 75 Tomás MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 22-09-2006 17:37
