Rover 45 Won't start - MG-Rover.org Forums
post #1 of 6 (permalink) Old 16-09-2010, 01:39 Thread Starter
Rover 45 2005 facelift model 10000 miles, won't start unlocks with fob however when key is turned to enable the ignition the central locking tries to unlock and the hazards come on, car can be cranked but fails to start, any thoughts
shugs is offline
post #2 of 6 (permalink) Old 16-09-2010, 09:52
01379 669375
Car: Vauxhall ASTRA GTC VXR
Won't start
Hi
If your immobiliser light is on on the dash board you will require the EkA code which will over rided the immobiliser so you would then be able to start your vehicle.
MG-ROVER-CODES is offline
post #3 of 6 (permalink) Old 16-09-2010, 14:43
Car: Rover 45 Impression L Series
Originally Posted by MG-ROVER-CODES View Post
Hi
He said it cranks so it is not the immobiliser coming on.
Sounds like either the central locking playing games or the SCU to me.
Plus, EKA entry is decidedly "dodgy" on facelift cars.
to the OP. Will it keep cranking or just turn over once and stop once the central locking kicks in?
When you say the hazards "come on", do you mean they stay on or just give the "car locked" flash sequence?
XPart02 is offline
post #4 of 6 (permalink) Old 17-09-2010, 07:13
Car: NOW HAVE A 25, 45 & 75
try disconnecting car battery and see if it will reset the electrics
LORDPSK is offline
post #5 of 6 (permalink) Old 17-09-2010, 17:07
check the central locking sensors on the door frame as i had this problem swapped the back ones to the front and hey presto
pete26671 is offline
post #6 of 6 (permalink) Old 22-09-2010, 02:26 Thread Starter
Problem sorted, I found that the cable to the fuel cut off switch was not fully pushed home, now starting again without any problems, many thanks for taking the time to reply to my post
shugs is offline
rover 45 wont start williamcadger MG ZS / Rover 45 & 400 7 01-04-2010 20:11
Rover 45 wont start. Single click when trying to start? steviejam73 MG ZS / Rover 45 & 400 8 14-01-2010 20:21
Rover 45 TD will not start Stressedbeaky Diesel Forum! 24 01-04-2009 19:19
Rover 45 Diesel will not start Rob20 Diesel Forum! 11 14-07-2008 21:32
Rover 45 won't start Bigdh MG ZS / Rover 45 & 400 1 13-01-2008 07:13
