symptoms - need help - MG-Rover.org Forums
post #1 of 8 (permalink) Old 30-11-2008, 21:53 Thread Starter
ok so previously had a thread regarding h/g but most people are not thinking that this is the problem.
so these are the symptoms:
Hard starting - always starts but takes a while
white smoke - not talking a little. (was parked outside tesco and 4 minutes of idling started to fill the litlte shop with smoke and was told to cut the engine
random hissy sound from engine
genrally noisy engine
not really got as much power as it had
any ideas to the problems (its just had a new cambelt and waterpump)
zemon is offline
post #2 of 8 (permalink) Old 30-11-2008, 22:12
Car: rover 45 impression S3
is it petrol or diesel
oddjobx1 is offline
post #3 of 8 (permalink) Old 30-11-2008, 22:28
Car: Audi Q7 3.0tdi Quattro Sline
Did all this happen after the belt and pump?
martibhoy1975 is offline
post #4 of 8 (permalink) Old 30-11-2008, 22:45 Thread Starter
no we brought a puppy. there was other symptoms ie water leak which didnt appear to be comming form waterpump but when changed resolved that problem.
its a 416i petrol 4dr saloon 1997
zemon is offline
post #5 of 8 (permalink) Old 30-11-2008, 22:50
Headgasket/inlet manifold gasket problem.
Sounds like theres slight water leak into a cylinder thats whats causing he white smoke and hard starting and power drop
post #6 of 8 (permalink) Old 30-11-2008, 22:53 Thread Starter
might try the inlet manifold gasket first
is it easily done on these. is it like doing the exhaust manifold gasket?
zemon is offline
post #7 of 8 (permalink) Old 30-11-2008, 23:50
1 Yeah unclip the air filter lid
2 three 13mm nuts at the top of the manifold just at the rear of the cam over.
3 two 8mm srews at the rear of the manifold holding the fuel pipe to the manifold removed to let pipe be moved for access
4 four 10mm or 13mm bolts under the manifold you can get them with a 6inch or so extension.
5 pull the manifold back and tilt up to reveal the rubber gasket and replace.
6 rebuild in reverse add water and anti-freeze and bleed through the 8mm on the coolant pipe.bleed screw located just under the dizzy cap under.also just under the main air intake pipe.
post #8 of 8 (permalink) Old 02-12-2008, 20:47 Thread Starter
sounds like an easy enough job
zemon is offline
Fan Symptoms Iznik MG ZT / Rover 75 (Sponsored by Rimmer Bros) 0 26-11-2007 12:17
withdrawl symptoms billo MGF and MGTF (Sponsored by MGFnTFBITZ) 23 30-12-2006 16:02
What would be the symptoms of this gusco MG ZR / Rover 25, 200 & Streetwise 17 20-12-2006 07:36
Withdrawal Symptoms!! Linda C MGF and MGTF (Sponsored by MGFnTFBITZ) 42 09-07-2005 09:38
