Are these 5 fault codes expensive to fix? - Page 2 - MG-Rover.org Forums
 2Likes
post #21 of 33 (permalink) Old 10-11-2016, 20:41
When I read the codes the fan was constantly kicking in and out so I read the live data which was fluctuating at around 130', the car didn't smell hot but we didn't lift the bonnet.
I am not familiar with the diesel but all other live data looked ok.
My guess was a failed coolant temp sensor.
I didn't clear the codes as we wouldn't have an opportunity to re-read them, it was more so Chris had a starting point for investigating his intermittent running problem.
Of the two temperature sensors the blue one will be for the gauge, the one for the ECU is probably blue or brown.
Chris.mas87 likes this.
post #22 of 33 (permalink) Old 10-11-2016, 21:57
Banned
I often get customers to photo my screen showing their codes,before deletion should they want reference.Then again once we know whats left.
Talkingcars likes this.
JT Dent is offline
post #23 of 33 (permalink) Old 11-11-2016, 18:44
Good idea JT, I copy the text from the pscan window and copy it into an email.
post #24 of 33 (permalink) Old 18-11-2016, 18:40 Thread Starter
So it turns out 3 of the fault codes are all linked. 2 disappeared when cleared and have not come back.
The fan, air con and acceleration/power problems are all linked.
The mechanic tested all the sensors. All work fine, so he opened up the main wiring loom. No obvious signs of damage. But when the wires were disturbed, the aircon began to work. Then fan didn't cut in either. But then after a while the 3 codes and problems returned. Fiddle with the wires and problems disappear again. Very confused as to possible cause
Sent from my iPhone using Tapatalk
Chris.mas87 is offline
post #25 of 33 (permalink) Old 18-11-2016, 18:42 Thread Starter
P.s. They think the accelerating problem like hiccups, is cause when the fans cut in. As they draws so much power. I did notice it only happened when the fans were on (which is almost all of the time)
post #26 of 33 (permalink) Old 18-11-2016, 20:31
If moving the wiring loom clears the problem then there is a problem with the loom.
post #27 of 33 (permalink) Old 18-11-2016, 20:32 Thread Starter
Yeah that is what I was thinking. At least all the sensors are working. Will see what they say (had the car a week now) kind of need to back soon. Are looms available?
post #28 of 33 (permalink) Old 18-11-2016, 21:27
Bren10's Avatar
Did you not see my reply on the 9th, it was on your second other post regarding error codes ? I did say to check the loom. Hope they can pin point the fault.
Bren10 is offline
post #29 of 33 (permalink) Old 18-11-2016, 21:30 Thread Starter
Sorry, must have missed that . Guess wiring problems take as long as they take to fix. Fingers crossed. Hope it isn't the ecu
post #30 of 33 (permalink) Old 18-11-2016, 21:32 Thread Starter
Also, even though the problems and three error codes return. The eml has never come on?!
post #31 of 33 (permalink) Old 19-11-2016, 15:34
The MIL will only come on with a fault directly affecting the emissions.
post #32 of 33 (permalink) Old 19-11-2016, 15:48 Thread Starter
Thanks James, good to know it isn't duff haha. Hopefully will get the car back at some point next week
post #33 of 33 (permalink) Old 22-11-2016, 20:38 Thread Starter
So fingers crossed, it is fixed! Hope it lasts!!
fault codes mad Diesel Forum! 0 17-02-2011 17:53
Fault codes?? boothy90 Diesel Forum! 9 23-05-2010 13:44
My 75 1.8 is overheating - is it expensive to fix! madengland MG ZT / Rover 75 (Sponsored by Rimmer Bros) 11 04-05-2010 16:20
fault codes sheffwedfan MG ZR / Rover 25, 200 & Streetwise 6 16-01-2010 17:35
fault codes stevie_g Diesel Forum! 2 04-08-2009 20:16
