Walbro Gss342 255lph pump? - MG-Rover.org Forums
post #1 of 6 (permalink) Old 13-03-2017, 20:10 Thread Starter
Hi all,
I'm wanting to fit a Walbro Gss342 255lph pump but it appears it won't fit the original mg zs 180 casing / fittings. It's 30mm shorter than the original walbro erj197, the bottom filter is different so it doesn't hold in the original case. And the outlet doesn't fit the outlet connector, also due to the 255 pump terminals being in the way.
Hoping someone has fitted one with success?
Thanks,
Connor.
MG_ZS_180 is online now
post #2 of 6 (permalink) Old 13-03-2017, 20:25
Fuel pump?
post #3 of 6 (permalink) Old 13-03-2017, 20:28 Thread Starter
Originally Posted by Talkingcars View Post
Fuel pump?
Yes sorry, forgot to mention it's a fuel pump.
post #4 of 6 (permalink) Old 13-03-2017, 20:29
Out of interest why you fitting a W255? They fuel 400bhp Mitsubishi Evo's be a bit of a over kill wont it
JOHNDQ is offline
post #5 of 6 (permalink) Old 13-03-2017, 20:31 Thread Starter
I'm doing a supercharged engine conversion with the janspeed 2.0L kv6. It has 460cc Injectors and will run around a bar of boost. So the original pump would be right on the limit.
post #6 of 6 (permalink) Old 13-03-2017, 23:20
Nice one cant help you on info tho I'm afraid. Might be worth looking in demon tweaks site they do a lot of intank pumps might find one more suited if not maybe go for a swirl pot and external pump like a Bosch 044
JOHNDQ is offline
Later model pump failure, easiest fix = replace pump? ste91 Diesel Forum! 1 12-02-2013 15:24
K series Alternator, Power Steering Pump, Air Con Pump, Starter Motor ZS Phil For Sale 2 21-02-2012 16:44
How to upgrade fuelpump with Walbro 255 lph xr3tf MGF and MGTF (Sponsored by MGFnTFBITZ) 10 06-10-2011 19:00
Walbro Fuel pump 255lph Si220T For Sale 0 03-03-2005 21:35
