Weird compression test result - MG-Rover.org Forums
post #1 of 3 (permalink) Old 18-03-2016, 14:43 Thread Starter
I just did a compression test on my 1.4 K Petrol.
I did it with the throttle closed - I know that I should have done it WOT.
Anyway, throttle closed I got 120 PSI on #2 #3 #4.
On cylinder #1, I got nothing.
This is not credible because the car runs fine on all 4 (other than coolant consumption) and I can feel a compression puff similar to the other cylinders with my fingers.
My first thought was bad seal, so I cleaned it up down in the spark well. The tester has a rubber ring on it, in good condition. The tester thread isn't that long, not as long as a spark plug.
I also couldn't detect a leak around the spark-plug with engine running. So I think thread is ok.
Any ideas please? I am suspecting IMG internal leak, trying to test HG when this happened.
Engine warm at time.
Also, #1 plug not discoloured or anything.
Bunsen Honeydew is offline
post #2 of 3 (permalink) Old 18-03-2016, 15:36
Test it at WOT. Results are pointless otherwise.
post #3 of 3 (permalink) Old 18-03-2016, 17:34 Thread Starter
Went back to do it again and suddenly worked fine, open or closed.
MOT Test result! benson180 MG ZS / Rover 45 & 400 6 13-02-2012 10:34
new bulbs, weird result? jimbo2260 MG ZS / Rover 45 & 400 10 08-01-2012 11:46
Chemical test - negative result v-man MG ZS / Rover 45 & 400 13 25-04-2010 23:44
MOT Smoke Test Result Dr Dave Diesel Forum! 23 24-05-2009 15:46
Result of todays MOT test is..... Neil.R MGF and MGTF (Sponsored by MGFnTFBITZ) 12 15-04-2008 21:43
