Windscreen Washer and Driver's Side Passenger Window Not Working - MG-Rover.org Forums
post #1 of 5 (permalink) Old 16-03-2017, 14:07 Thread Starter
My Windscreen washer/jets and drivers side rear window have stopped working. I thought it might be the fuse so replaced it as I noticed there is one that is used by both the window and jets, however, it hasn't fixed anything. There is also a 20 amp fuse that is used by both jets that I changed but it didn't fix anything. Also on the fuses I pulled out I couldn't see that the fuse was blown (but don't know for sure you could see it has blown).
I'm guessing there's an electrical fault, where would I start to look?
Ben
bendort is offline
post #2 of 5 (permalink) Old 16-03-2017, 17:00
First of all what car and model year we are talking about here? This section and car model in your profile are pretty different.
post #3 of 5 (permalink) Old 17-03-2017, 10:05 Thread Starter
Sorry, it's currently a Rover 45, diesel model (1.9l) from 2005.
bendort is offline
post #4 of 5 (permalink) Old 17-03-2017, 17:06
I looked at the diagrams and I cannot find any point where these two problems are connected. They even do not share same fuse or earth point.
I would take multimeter and treat these two things as saparate problems. I would start measuring power on the window switches and driver motor. Also on the pump for jets.
post #5 of 5 (permalink) Old 20-03-2017, 10:00
Car: MG ZS 120+ , MG ZR TD, MG TF 135 and MG3 Style.
Windscreen washers will be a failed relay in the BCU. I lost intermittent wipe when mine failed along with something else which I cannot remember.
Rear door window I don't think is driven by the bcu so this could be an issue with the motor itself.
michaelb is offline
Driver side heating warm, passenger side cold! hh1 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 20-01-2013 11:17
driver side window not working rover_all_over Rover 600 8 30-03-2011 13:21
Driver Side front Electric window not working what should I look 4? Rover 25 (51 Reg) Mintygreen MG ZR / Rover 25, 200 & Streetwise 10 16-07-2008 22:24
rear windscreen washer not working shocka144 MG ZR / Rover 25, 200 & Streetwise 8 26-04-2007 15:26
