Is your clutch pedal high on your 400/45/ZS? Take a look here... - MG-Rover.org Forums
post #1 of 358 (permalink) Old 19-07-2010, 13:48 Thread Starter
Car: MG ZT-T+ CDTi Auto
Now in stock - 20+ kits ready to send.
Fit the original and best!
http://www.dmgrs.co.uk/collections/r...adjustment-kit
Hello all!
Next time you get in your car, see if you have any free play at the top of your clutch pedal. If it feels very light at the top part of the pedal travel - read on...
Been working on the ZS, ready to make it my daily again.
One thing I've noticed is that the clutch pedal is higher than the others, with a lot of 'free play' at the top of it's travel before it has any effect on the master cylinder.
To check if this kit will solve your issue, with your hand push your clutch pedal down. If there is a bit of travel where it's very easy to push, then a little later it gets much harder, this will work for you.
This works with:
Rover 400 - All models
Rover 45 - All models
MG ZS - All models
The high pedal is pretty annoying at the best of times, I remember this used to give my left foot quite a good work out when it was my main car!
Anyway, I've been working on a fix for it, a simple bolt-on device that cures this issue once and for all, and makes your clutch sit in line with your other pedals. It won't increase wear, adjust the biting point etc, just make the pedal sit at the right height for easy driving and not practically touching the dashboard.
I'm 6ft 3 and fitting in a ZS isn't that easy, I pretty much have to knee myself in the face to use the clutch.
I'll be happy to make them for fellow forum members at cost price plus a little for time and P+P.
It mounts to a spare hole in the pedal box, and is a small metal bracket held by a bolt and Nyloc nut, and holds the pedal in the lower position when released. I have made sure the bracket and mounting is strong enough for this, seems to work well.
It is supplied with a number of adjustment washers - work out where you want the pedal to sit (just as the master cylinder provides resistance is the most sensible point, and makes the pedal level with the others) and then when mounting the bracket with the bolt use as many/as little of the washers as needed.
A guide is included.
Included:
1x High Tensile bolt, hex head
1x Nyloc nut
1x Clutch pedal adjustment bracket
2x large washers, for mounting the bracket to the pedal box mounting point
10x smaller washers for spacing to make the pedal height how you wish
Total cost is 5.25 including post and packaging.
Fitting is easy - you'll need a couple of spanners and half an hour.
Click here to order - http://www.dmgrs.co.uk/collections/r...adjustment-kit
Any questions?
DMGRS is offline
post #2 of 358 (permalink) Old 19-07-2010, 13:52
C-J
Car: ROVER 45 IMPRESSION S
I'm in.
C-J is offline
post #3 of 358 (permalink) Old 19-07-2010, 13:55 Thread Starter
Take it you have a diesel? If so, I will PM you when I have it ready. I will also post pictures of the kit.
Mat
DMGRS is offline
post #4 of 358 (permalink) Old 19-07-2010, 14:05
C-J
Mat
Petrol mate,i should learn to read .
C-J is offline
post #5 of 358 (permalink) Old 19-07-2010, 14:11 Thread Starter
It might still work, is it a 1.8? I will find out if it's compatible, at the moment I only have access to the diesels.
Will get back to you and update. Does it have the free play and high travel as described at the beginning of the thread?
DMGRS is offline
post #6 of 358 (permalink) Old 19-07-2010, 14:17
C-J
Yes it does mate,its a 1.4.
C-J is offline
post #7 of 358 (permalink) Old 19-07-2010, 14:21 Thread Starter
Excellent, I will find the pedal box diagrams and get back. Cheers!
DMGRS is offline
post #8 of 358 (permalink) Old 19-07-2010, 14:35 Thread Starter
I can confirm this kit works with ALL MODELS!
DMGRS is offline
post #9 of 358 (permalink) Old 19-07-2010, 15:05
Count me in please.
Rob180 is offline
post #10 of 358 (permalink) Old 19-07-2010, 15:20
Car: 180 (trophy blue)
ahhhh!!! im defo in! being 6'2" its a bloody pain in the arse especially when all other aspects of driving my ZS are great.
macaceuk is offline
post #11 of 358 (permalink) Old 19-07-2010, 15:20
if it will work on my 1.8 120, and its not hard to do, count me in!
stevedx is offline
post #12 of 358 (permalink) Old 19-07-2010, 15:30 Thread Starter
Cheers for the support guys
It's simple to do, there is already a mounting point in the area and it will take about 15-30 mins to complete this modification. I will email a guide out when I get some pictures taken.
Mat
DMGRS is offline
post #13 of 358 (permalink) Old 19-07-2010, 15:58
Cool ... Add another one to the list.
ukbiker is offline
post #14 of 358 (permalink) Old 19-07-2010, 17:12
Car: ZS+ 170TD
yup me three on that one.. since i did the swap to the 600 bits it got even higher on mine.. lowering it will be useful to say the least.
Tho quick question; i assume it can cope with the extra weight of my system.. tho for a couple of quid if it doesn't last then no real big issue
p_b82 is offline
post #15 of 358 (permalink) Old 19-07-2010, 18:02
Car: 45 2.0 Diesel
I'll have one mate, Sheddist offers a similar solution as part of his famous ZS180 clutch kit - which doesn't fit the diesels, I've been meaning to get round to knocking myself one up but never seem to have the time!
Count me in, and see if you cant come up with the rest of the sheddist kit for a diesel while you're at it lmao!
Chrisund123 is offline
post #16 of 358 (permalink) Old 19-07-2010, 18:03 Thread Starter
It will cope, I've designed the bracket to outlast the car itself - no point doing it on the cheap!
Bolt is an M6 too, so you'll have no worries.
I'll drop everyone a PM soon, I'm currently developing the bracket assembly to make sure it has as much contact area with the pedal arm as possible.
DMGRS is offline
post #17 of 358 (permalink) Old 19-07-2010, 19:11
Car: 25 Track Car in Prog...
Ill take a kit when ready dude.
Tom163 is offline
post #18 of 358 (permalink) Old 19-07-2010, 19:40 Thread Starter
Cheers. Sorting out final pricing now! Will be ready to take orders later tonight.
DMGRS is offline
post #19 of 358 (permalink) Old 19-07-2010, 20:09 Thread Starter
Now available to order at 4.25 per kit!
First batch will be being made tomorrow. I will PM those that have already replied.
DMGRS is offline
post #20 of 358 (permalink) Old 19-07-2010, 22:52
Car: MG ZS 180+
Put me down for one
Jay-ZS+ is offline
high clutch pedal in zs 180 welderwill MG ZS / Rover 45 & 400 17 10-07-2010 21:56
rover 45 high clutch pedal bravo1 MG ZS / Rover 45 & 400 2 24-04-2009 18:56
rover 45 clutch pedal high !! nelliened MG ZS / Rover 45 & 400 3 24-07-2008 13:58
rover 45 2001 clutch pedal is too high how fix it? misio_p MG ZS / Rover 45 & 400 2 01-05-2008 14:41
ZS High Clutch Pedal keir1163 MG ZS / Rover 45 & 400 14 10-01-2008 20:43
