ZS 180 Temp issues - MG-Rover.org Forums
post #1 of 4 (permalink) Old 19-03-2017, 13:52 Thread Starter
Car: Rover 211 MG ZS 120 MG ZT 160T ZTT 120 MG3 Style MG ZS 180
Red face ZS 180 Temp issues
Hi all,
recently bought a ZS180. The car was great on the journey home, but a split coolant pipe meant it went to the garage for a while. However, the temp gauge goes above half way, more towards 3/4 mark after about 20 minutes running. It goes back to normal if I put the heater on though. Ive spoken to a few owners and it seems to point towards a thermostat issue. Im willing to get it fixed, however I don't trust my local garage. I was charged 300 to fit an 18 pipe as they couldn't locate the issue at first. I took it back but they claim its running fine, more like they aren't interested, they just said it might be HG....on a V6.
Its not loosing coolant, so I don't think its anything major. Just after a second opinion and if anyone can recommend a MG specialist near Kettering, Northants.
mattie007 is offline
post #2 of 4 (permalink) Old 19-03-2017, 23:47
Car: 2003 ZS180 Mk1
Not an expert, but sounds like it is either the thermostat or air in the system. I thought there was a certain way to fill the system, which involved using the plastic bleed screw in one of the coolant pipes (next to the block, just below and forward from the throttle body) - maybe the garage you used have not bled it properly after refilling? Might be worth finding the filling procedure, and draining the system and refilling it properly. Wouldn't take long to do.
With regards Mg specialists, sorry, don't know of any personally in the area. When I had my belts and water pump changed, I had the guy from Derby come down (just outside of Kettering). MG Rover Mobile Specialists or something like that. Another possible is a guy over in Olney. Phil-T4 on the forums. Although a small job, he did my key fobs a few years ago, and was saying he does work on Kv6's although at the time was more ZT, I think. Might be worth a call? Also called MGR T4 Services.
glane85 is offline
post #3 of 4 (permalink) Old 20-03-2017, 14:31
Car: MG GS Exclusive DCT
Have a look at Lates600
R8NMG is offline
post #4 of 4 (permalink) Old 20-03-2017, 22:58
Bren10's Avatar
I would say air in system if thermostat was working ok before, when I used to do coolant change on my V6 as mention above there is a plastic bleed screw in the hose next to block. It's very simple to refill system on these engines I never had an issue. I did it a second time when I changed the thermostat, housing and plastic pip on top of block which is another common fail,point.
Your garage doesn't seem upto the job and I would take action if you manage to sort it your self.
Bren10 is offline
Temp issues. Celestial 20 MGF and MGTF (Sponsored by MGFnTFBITZ) 2 07-12-2014 20:51
Temp issues is this the jingle valve? Hot air going cold and temp gauge going up trophyblue02 MG ZR / Rover 25, 200 & Streetwise 8 08-11-2012 20:07
temp guage issues shaunbing MG ZR / Rover 25, 200 & Streetwise 7 21-08-2012 16:32
temp issues! bourneyo MG ZR / Rover 25, 200 & Streetwise 11 20-01-2010 11:47
Temp Issues badger666 MG ZR / Rover 25, 200 & Streetwise 11 17-05-2008 19:28
