zs boot lid - MG-Rover.org Forums
post #1 of 8 (permalink) Old 10-02-2014, 21:43 Thread Starter
zs boot lid
hi has any one fitted gas struts to a mk 1 boot lid if so any pics or how to.many thanks Allan
daryl1104 is offline
post #2 of 8 (permalink) Old 11-02-2014, 19:18
Car: 2003 MG ZS 180 (Saloon)
Have a look on XpowerForums, I'm sure someone on there did a gas strut conversion although from what I remember it didn't prove too successful.
top_man_eldo is offline
post #3 of 8 (permalink) Old 11-02-2014, 20:04 Thread Starter
boot lid
ok thanks I,ll do that
post #4 of 8 (permalink) Old 11-02-2014, 21:56
Car: MG ZS120(2005) ■■■■■□□□□□□
Why do you want to?
If it is because the spring wont hold the big spoiler up then most people seem to solve the problem by tightening the spring...
As said, a search on XpowerForums should give an answer.
Windy is offline
post #5 of 8 (permalink) Old 12-02-2014, 20:54
Car: Rover 25 iXL, MG ZS 120+
So how do you tighten the spring? My boot will not stay up reliably, and adding a gas strut (where? What type?) seems like a plan...
richw is offline
post #6 of 8 (permalink) Old 13-02-2014, 15:28
Car: Mk2 MG ZS 180
Look in the boot. There is another position for the torsion bars. Try that.
Munch is offline
post #7 of 8 (permalink) Old 14-02-2014, 21:02
Already in the tightest position. Still crapola.
richw is offline
post #8 of 8 (permalink) Old 16-02-2014, 03:28
I tried using the boot strut from my old BWM. It put too much pressure on and lifted the boot on that side.
I did find a solution for the springs tho. Take a piece of wood/plastic/metal about 5cm x 2cm x 2cm high (you may need to play with height, depending on the amount of slack you have)
Cut a small notch the width of the spring bar across the top:
---u--- Side view
## Top view
Sort of like that if you can imagine it.
Make one for each side. Now comes the dangerous bit. There is a real chance of taking off the end of your finger if you are not careful.
Use something to lever against the bit of spring that is sticking out at the back (I used the handle of a large wrench), and lift up the front bit of the spring. Slip the block under the bar where it sits on top of the hinge. Carefully lower the spring back onto the block. Repeat other side.
Done.
This puts a little more pressure on the spring bar, and will hold the boot open. It may not last for ever, but has done me well for a few months now.
I will try and get some pics of it in action.
MrTomWins is offline
Boot Lid geo29 MGF and MGTF (Sponsored by MGFnTFBITZ) 3 06-03-2013 11:43
MK 2 Boot Lid RickZRTD MG ZR / Rover 25, 200 & Streetwise 36 09-04-2009 22:30
Boot Lid??? liamodell MG ZS / Rover 45 & 400 4 08-11-2008 09:30
TF Boot Lid for an F? PERRY-MGTF MGF and MGTF (Sponsored by MGFnTFBITZ) 8 19-06-2006 17:24
boot lid zs 4 Dr Carl MG ZS / Rover 45 & 400 3 10-09-2005 06:35
