ZS clock light not working. - MG-Rover.org Forums
post #1 of 11 (permalink) Old 21-04-2005, 10:43 Thread Starter
The light on my clock in my 2002 ZS is not working, I have searched on the forums and would I be correct in thinking it must be the clock itself because the interior light is ok? (Same fuse?).
Is it easy to get to the clock to see if it is a bulb or something?
Thanks.
ngrif is offline
post #2 of 11 (permalink) Old 21-04-2005, 10:47
Car: Something Else
The Major is probably the best guy to ask on how to get to it (unless someone else has done it on a 400/45/ZS), i would have thought it could require the dashboard to come off (unless the clock pops out on it's own?)
Schtopper is offline
post #3 of 11 (permalink) Old 21-04-2005, 10:47
there is also a fuse under the bonnet but this does the radio as well
prob the clock
if it were me i would go scrappers and just get one from there
wirly is offline
post #4 of 11 (permalink) Old 21-04-2005, 11:42 Thread Starter
Thanks for the quick response, if it is a case of taking the dashboard to pieces though, rather than just a few clips I think it may have to stay broken for a while
ngrif is offline
post #5 of 11 (permalink) Old 21-04-2005, 16:38
99% it is the bulb.
Unfortunately on the 400/45/ZS it is a ***** to do!
Procedure as follows.
1. remove the two screws at the back of the back part of the centre console.
2. remove plastic cover from centre console centre (under handbrake).
3. remove the 2 10mm bolts.
4. remove rear part of centre console (lift and push towards back of car, disconnect electric window switches, then lift over handbrake)
5. remove radio and radio mounting cage
6. remove screw in radio apature
7. remove heated rear window and hazard light switches
8. remove screws revealed by following 7.
9. remove two screws in centre console in footwell.
10.remove gear knob
11 remove leather gear surround (clipped in pull up from front end)
12 remove centre console (disconnect clock wiring).
13. Bulb is in the back of the clock.
14. refit is reverse of removal!
cjmillsnun is offline
post #6 of 11 (permalink) Old 21-04-2005, 16:48
Car: MG ZT 180 SE in XPG.
you can do it by just taking the radio out and the metal bit that holds the radio. you can then slide your hand through the hole and twist the bulb out. its tricky but you can do it. ive done it and i got big hands.
MattL is offline
post #7 of 11 (permalink) Old 21-04-2005, 17:01
yeah, you are right. When I did it I had to change the display as I had missing segments (not good for the radio)
post #8 of 11 (permalink) Old 21-04-2005, 17:14
i know im right. lol
MattL is offline
post #9 of 11 (permalink) Old 21-04-2005, 18:14 Thread Starter
Thanks, I will give it a try!
ngrif is offline
post #10 of 11 (permalink) Old 21-04-2005, 21:09
you might as well. its a small screw in bulb with a green (i think) back. if you could get a mirror in there first to see what your dealing with it would help. its only about 10-12mm in diameter so be very careful not to drop it.
MattL is offline
post #11 of 11 (permalink) Old 22-04-2005, 06:19
i popped the clock out on mine
i removed radio put hand up and the radio hels in with clipe pushed one and it pops out then you can remove bulb or swap unit
wirly is offline
clock not working pandaman MGF and MGTF (Sponsored by MGFnTFBITZ) 2 22-06-2008 16:03
Clock not working 416 MG ZR / Rover 25, 200 & Streetwise 3 06-08-2007 22:42
Clock not working......... Cossie Killer MGF and MGTF (Sponsored by MGFnTFBITZ) 16 10-02-2007 17:12
Clock not working tasng4 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 10-07-2006 22:14
clock light zs Grey MG ZS / Rover 45 & 400 9 04-10-2005 19:18
