zs manifold cure - MG-Rover.org Forums
post #1 of 8 (permalink) Old 13-12-2012, 23:00 Thread Starter
Car: Rover 600
Exclamation zs manifold cure
Ive recently bought a brand new inlet manifold and vis motors but i wanna know if theres anything i can do to prevent the rattle coming back. Ive heard of fitting a catch tank but all the ones ive seen all have the inlet and outlet port close together with no filter meaning big droplets will be collected but any fine mist is going into the manifold! Short of venting to atmosphere i cant think of anything else. Im not sure if you want a lil bit of oil coming into the manifold to lube the buttetflys would be helpfull. Sorry to.repeat threads i did search the forum but couldnt find the info i wanted. Any replys would be helpful cheers guys!
british classic is offline
post #2 of 8 (permalink) Old 14-12-2012, 02:02
Send a message via Skype™ to fathead431
many end up removing the VIS motors and valves completely, theres lots of threads on removal
fathead431 is offline
post #3 of 8 (permalink) Old 14-12-2012, 09:42 Thread Starter
Car: Rover 600
Wink eC
lol yeah ive seen lot of people do that but im convinced there must be a way of saving them
post #4 of 8 (permalink) Old 14-12-2012, 12:20
ZeV
Car: 04 ZS 180 MK2
Apart from a oil catch tank I don't think there's any other options, I was thinkin of buying a brand new one and putting a catch tank on the big vacuum hose and leave the smaller one, personally I wouldn't want any oil going in there to be burned, but I've decided to pocket the cash and just rip the valves out lol.
ZeV is offline
post #5 of 8 (permalink) Old 14-12-2012, 18:06 Thread Starter
Car: Rover 600
Thumbs up
Well id bought several second hand manifolds over the use and they all end up the same way think ill just keep buying new ones normally get good 40-60k before they start ratting just hope catch tank does the job maybe even a in-line fuel filter. Cant say i blame you 465 for manifold and vis motors bank balance is hurting lol
post #6 of 8 (permalink) Old 14-12-2012, 22:39
I think the problem is the heavier oil getting through, the fine mist will help keep the valves lubricated.
post #7 of 8 (permalink) Old 15-12-2012, 00:24
Something to think about , my car is on the original manifold ( 9 years old ) the car has a catch tank on the small pipe , but its been run on fully synth 5w40 oil from 1000 miles , I wonder if this slightly thinner oil has made a difference ?
Carl is offline
post #8 of 8 (permalink) Old 15-12-2012, 22:35 Thread Starter
Car: Rover 600
I opened up my last manifold seems like a mixture of oil and carbon. The thinner oils prehaphs not a bad idea. Its obv. Worked with your.
Thanks for replys!
A cure at last. renagade MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 22-04-2012 19:29
Acne cure. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 25 03-07-2010 17:59
Cure possible misfire. Figo MG/R Modification & Tuning 1 08-12-2009 21:45
new clutch cure? marius v MG ZT / Rover 75 (Sponsored by Rimmer Bros) 11 04-09-2009 21:39
Someone please come up with a cure.... VOLVO-MASTER MGF and MGTF (Sponsored by MGFnTFBITZ) 27 05-10-2007 12:02
