ZS rear silencer on a 45? - MG-Rover.org Forums
post #1 of 8 (permalink) Old 19-07-2014, 16:40 Thread Starter
Car: Rover 45 Club SE, 205 Gti
Hi all, I am going to replace the rear silencer on my mk2 1.6 45 hatchback soon. I prefer to see the pipe like on the zs. After some searching, I found I would need the mk2 hatchback silencer and obviously the bumper trim. Has anyone else done this, as the posts that I found were vague.
Ian
mogsman is offline
post #2 of 8 (permalink) Old 19-07-2014, 20:34
tail pipe
yep i did it last year. i was having a full s/steel system fitted.
you will need the alloy trim from a ZS 1.8 or 2.5 V6 as the 1.6 wasnt fitted with the trim, along with the trim you also need the 4 screws and nuts plus the rubber gasket for fitting. when you buy the parts make sure you get the correct one as hatch and saloon are different ( i have a spare trim for a saloon in the shed as i bought the incorrect trim first time ).
Bren10 is offline
post #3 of 8 (permalink) Old 19-07-2014, 20:49 Thread Starter
Thanks Bren, I'll keep my eyes peeled for the hatch trim. Just wanted to be sure that the exhaust parts would bolt up.
Ian
mogsman is offline
post #4 of 8 (permalink) Old 19-07-2014, 21:34
tail pipe
the only difference is a longer tail pipe after the silencer, the 45 and 1.6 ZS have the turned down tail pipe. i did have a diagram on A4 from when i cut my rear bumper, i will see if i can find it for you.
i cant see any trims on ebay at the mo but there are a couple of rear bumpers on there for 60 the one is damaged and has been on there for ages, you could try making them an offer on the trim, maybe worth a try.
best of luck Bren
Bren10 is offline
post #5 of 8 (permalink) Old 20-07-2014, 23:38
bracket
hi again, had a thought today while down my shed. when you cut the bumper for the trim it will become floppy on the driver side, the reason for this is the Zs car with the trim have a bracket fitted to the bumper to support it and help keep it from flexing to much.
i made my own from alloy as they are no longer available from rimmers, i do have one in the shed now but wont be fitting as i already have the alloy one on the car.
this the bracket
cutting bumper using a paper template i made
tools used , saw and drill for the bolt holes
finished job
Bren10 is offline
post #6 of 8 (permalink) Old 21-07-2014, 05:16
MARCOVH is offline
post #7 of 8 (permalink) Old 22-07-2014, 19:54 Thread Starter
Nice car Marco. Bren I have sent you a message about the support bracket. Is there a template for the cut out or is there a mark on the inside of the bumper. I can't remember seeing one when I last removed it putting a tow bar on.
Ian
mogsman is offline
post #8 of 8 (permalink) Old 09-08-2014, 07:00 Thread Starter
Bren, do you still have the template and the support bracket? I have pm'd you as well.
Ian
mogsman is offline
mg zr td rear silencer sk140882 Wanted 9 29-05-2013 15:18
Rear silencer mick45 MG ZS / Rover 45 & 400 0 09-06-2009 12:56
New Rear Silencer puddingandpie MG ZR / Rover 25, 200 & Streetwise 2 06-07-2008 11:36
Rear silencer Oyster45 'R8' Rovers (aka Wedges!!) 2 05-07-2007 00:14
Rear Silencer imroberts MG ZR / Rover 25, 200 & Streetwise 7 24-06-2007 18:29
