'02 MG ZT 190+ low compression - MG-Rover.org Forums
post #1 of 4 (permalink) Old 14-03-2017, 20:09 Thread Starter
Hi all,
Ive had this car for a few months and it's my first ZT, after having two 400 and 200 series R8 and a MGF in the past.
The car wasn't perfect, but it was virtually a 1 owner from new and a full service history, with the belts changed a couple of years ago.
The engine wasn't very smooth and only a very minor judder at idle. Also, on startup, but not always, it would smoke a bit, but I took that as down to stem seals.
Despite a couple of issues that were easy to sort out, it has been a pleasure to drive.
Not long ago, I had a T4 session where it was detected that the balance ViS was faulty. I purchased and installed refurbished vis motors and sudddnly the big problems started. The car, although performed and acceletated better, it started to judder more on idle, as if it was misfiring. Then, the engine light came in. I used a generic code reader and it said that indeed there is a misfire on cylinder 1. The plug on cylinder 1 looked a bit oily, and the others were dry. Still, New plugs, swapped coils and cables... nothing. Still the damn misfire on cylinder 1 and the code reader says it fails to read the o2 sensor... but not showing showing up as an error in the ecu...
Well, Did a compression test and it's not good news.
Cylinders 2 to 6 gave a reading of around 170-180, the cylinder 1 gave around 100. Poured a teaspoon of oil into it and the compression jumped to the same as the other cylinders.
Question now is:
Change the oil to and add an additive to help temporarily recover some compression or sell the car?
Repairing it would be expensive, I assume?
Gentil89 is offline
post #2 of 4 (permalink) Old 14-03-2017, 21:17
dropping the front head off isnt a difficult job.. and liner and rings can be fitted in situ with the piston at the top..
keith8000_0 is offline
post #3 of 4 (permalink) Old 14-03-2017, 22:25 Thread Starter
My main point is, how expensive it is? Replacing the liner and the rings on the piston? But that would mean replacing the belts and that's not an easy or cheap job either..
Gentil89 is offline
post #4 of 4 (permalink) Old 15-03-2017, 09:28
it all depends on who is doing the job.. if you are capable it can be done for under 100. used liners and pistons are readily available.. . also if the belts have been done you dont need to replace them again maybe.. if a piston has a hole in it it can take a bit longer(I suspect it may have) but still just sump off job to get to the conrod bolts.. A garage may not want the job.. or you could buy a good used engine for 150 and slot it in, take you less than a day with an engine lift..
low compression Dnlshannon MG ZR / Rover 25, 200 & Streetwise 9 16-02-2013 14:00
Compression low Duffdef MG ZT / Rover 75 (Sponsored by Rimmer Bros) 22 26-10-2009 18:21
low compression sexycoupe MG ZS / Rover 45 & 400 9 25-01-2007 20:40
low compression on 45 daddy12340 MG ZS / Rover 45 & 400 14 11-08-2006 20:29
Low compression, thoughts please! Randyjim Others 16 29-03-2004 20:57
