Acronyms and Abbreviations - MG-Rover.org Forums
 3Likes
post #1 of 48 (permalink) Old 14-08-2010, 11:26 Thread Starter
Newcomers and other members may find this useful. I started it for the other forum and update it now and then. This is the square one edition. I've posted it after a new member asked about the meaning of 'FBH'. If members think it's useful, I'll add more to it as I get the inclination.
Please don't add anything by copy/pasting this list. Just let me know what you'd like to add by pm or making a separate thread. That way this post wont end up long difficult to read.
Acronyms and Abbreviations (last edited October 2011)
ABS = Anti-lock Braking System (An automated system to minimise wheel skid on braking)
BBUS = Battery Backed Up Sounder (Part of the alarm system)
BCU = Body Control Unit (an ecu managing electronic systems associated with the car itself)
CAN-Bus = Controller Area Network (High speed data link handling engine management, ABS, etc.)
CDT - Common Rail Diesel Turbocharged
CDTi - Common Rail Diesel Turbocharged Injection
DOHC = Double Over Head Camshafts (Engine design with separate inlet and exhaust valve camshafts mounted on the cylinder head)
ECU = Electronic Control Unit/Engine Control Unit (Electronic system that manages the engine and associated systems)
EGR = Exhaust Gas Recirculation (An emissions control system)
EWS = Elektronische Wegfahr Sperre (The Immobiliser ECU)
FBH = Fuel Burning Heater (Fitted to some early diesels to prewarm the engine in cold weather)
FFS = Fuel Filter Syndrome (A fuel starvation problem in post-2001 petrol models caused by a slackening of the filter module cap)
FIS = Fast Idle Solenoid (Part of the idle speed control system in petrol engines)
FOC = Fabled Orange Clip (A proprietory fixer for FFS)
HGF = Head Gasket Failure (Usually caused by an engine overheat)
IAC = Idle Air Control (System to control idling speed in petrol engines)
IACV = Idle Air Contol Valve (Part of the IAC)
HID = High Intensity Discharge (A high voltage plasma arc type lighting unit. Called 'xenon' lighting in the handbook.
I-Bus = Intelligent Input Bus / Infotainment Bus (Definition uncertain) (See K-Bus. For the 75/ZT I-Bus and K-Bus are synonymous)
ICE = In-Car Entertainment system
IPK = The Instrument Pack (Sometimes referred to as IKE. German: Instrumentenkombination-Elektronik)
K16 = The 16-valve (DOHC) version of MG Rover's K-series engine. Used in the 1.8 and 1.8 Turbo models (erroneously called the K18)
K-Bus = Body data network (From Karosserie, meaning bodywork. Slow speed link handling interior lighting, alarm, central locking, etc.)
KV6 = The 6-cylinder quad camshaft Vee format of the K-series engine. Comes in 2.0 and 2.5 litre capacities.
LCD = Liquid Crystal Display. The electronic system used for the dash screens.
LED = Light Emitting Diode (A lighting system 'bulb' using electroluminescence instead of a filament)
LPG = Liquified Petroleum Gas (The petrol engines can be modified to run on LPG and petrol)
LSM = Lights Switch Module (A box of electronics that sits behind the actual switch panel)
M47R = The designation given by BMW to the 2 litre diesel engine.
MAF = Mass Air Flow (A sensor to detect the quantity of air being drawn into the diesel engine inlet system)
OBC = On Board Computer (Basically part of the OBD system)
OBD = On Board Diagnostics system (Electronic system which monitors all aspects of engine performance and control)
OAT = Organic Acid Technology (The inhibitor system used in the recommended antifreeze. Has a 4-5 year service life)
PCV = Pressure Control Valve/Positive Crankcase Ventilation (A system to control the crankcase pressure in diesel engines)
VIS = Variable Intake System (A fuel control system fitted into the inlet manifold of the KV6 engines)
German/BMW Acronyms
A comprehensive list can be found here: http://www.autotechnik-forum.de/acronyme.php
Please don't copy/paste to this list. I'll edit it as new suggestions come in.
TC
T-Cut is offline
post #2 of 48 (permalink) Old 14-08-2010, 12:04
Car: MGF vvc MK2
Very Informative TC, PVC should read PCV I think, could you do a more informal one for numpties like me as in general speach eg
FFS
GTFO
WTF
plus a few more
John.
John Fla is offline
post #3 of 48 (permalink) Old 14-08-2010, 14:55
Car: Honda Odyssey EX-L
Excellent idea. One of my first questions when I joined this forum was asking if there was a glossary of some of this technical mumbo jumbo. Give me time and I am sure I will think of one or two myself.
Edd
Mr Edd is offline
post #4 of 48 (permalink) Old 15-08-2010, 09:29
Car: Jaguar X-Type Sport 2.5 V6. Peugeot 207 Verve 1.4 2010.
Good job TC. That clears things up nicely!
mgnev is offline
post #5 of 48 (permalink) Old 15-08-2010, 18:09 Thread Starter
PVC corrected, thanks.
could you do a more informal one for numpties like me as in general speech?
eg: FFS, GTFO, WTF, plus a few more
No, they're all in Wikipedia.
TC
T-Cut is offline
post #6 of 48 (permalink) Old 16-08-2010, 21:08
Car: Rover 75 2001 2.5V6 Connie SE Tourer
Well done again T-cut.
I wondered for some time what OP ment!---original poster
also OEM had me foxed when I first arrived here----original equipment manufacturer
All part of the jargon used in the forums
M
COLVERT likes this.
Martyn P is offline
post #7 of 48 (permalink) Old 16-08-2010, 21:11
M
You dont want to know what WTF means senior manager.
FLYER.
BTW excellent contribution as per T-C .
FLYER is offline
post #8 of 48 (permalink) Old 16-08-2010, 21:27
Minor Correction
VIS = Variable Input System (A fuel control system fitted into the inlet manifold of the V6 engines)
Should read "Intake"
post #9 of 48 (permalink) Old 16-08-2010, 21:27
Car: 75 Connie SE CDT
T4 is missing.
MAF is there twice
Repo is offline
post #10 of 48 (permalink) Old 16-08-2010, 21:29
Originally Posted by Repo View Post
T4 is missing.
MAF is there twice
At least that shows your paying attention , ya picky lot
FLYER.
FLYER is offline
post #11 of 48 (permalink) Old 16-08-2010, 21:31
All good edits - when these replies have been taken into consideration I expect I'll tidy the thread up making it more concise.
COLVERT likes this.
post #12 of 48 (permalink) Old 16-08-2010, 21:33
You mean delete the funnies , bloody mods .
FLYER.
FLYER is offline
post #13 of 48 (permalink) Old 16-08-2010, 21:41
OK OK....I meant delete the DRIVEL!
Seriosuly, this type of thread welcomes input to post#1, then I'll tidy up the posts. Keeps it 100% informative that way.
COLVERT likes this.
post #14 of 48 (permalink) Old 17-08-2010, 00:54
MAFAM perhaps?
UBP
Repo is offline
post #15 of 48 (permalink) Old 17-08-2010, 04:47
How about PTTM...
Peddle To The Metal...
Edd
Mr Edd is offline
post #16 of 48 (permalink) Old 18-08-2010, 21:06
ABS. Minimise ??? Avoid, rather. Colv.
COLVERT is offline
post #17 of 48 (permalink) Old 18-08-2010, 21:18
VIS. Variable induction system.
Changes the length of the inlet tracts for maximum torque at all engine speeds.
Not a fuel control system !!
Colv.
COLVERT is offline
post #18 of 48 (permalink) Old 21-08-2010, 09:58
mjt
Car: '99 75 Club SE 2L V6
Actually the Rover manual refers to it as a Variable Intake System
mjt is offline
post #19 of 48 (permalink) Old 21-08-2010, 10:55 Thread Starter
MAFAM
This appears to be Rover Ron's proprietary name for the improved MAF he sells. It's not clear to me what the extra 'AM' bit means. A far as I can see, his webpages doesn't clarify this. I'm sure there are hundreds of proprietary terms for items that may be used on these cars, but I don't think they should be included. The MAFAM is popular enough to scrape in.
TC
T-Cut is offline
post #20 of 48 (permalink) Old 21-08-2010, 14:15
Yes I read that myself too, but not wishing to appear a copycat I said "induction" which in the Concise Oxford Dictionary it says, " The drawing of the fuel mixture into the cylinders of an internal combustion engine".
Thus adding another description and furthering your education. Pmsl.
Old Sage, Colvert.
COLVERT is offline
FYI, motorists don’t get acronyms, etc. Ian Other Motoring Chat 18 05-01-2007 22:05
