Another 1.8T Hesitation under hard acceleration - MG-Rover.org Forums
post #1 of 14 (permalink) Old 10-05-2010, 01:26 Thread Starter
Car: '53' MG ZT+ 1.8T Anthracite , '05' ZT+ CDTI 135 Silver Sparkle
Hi guys as per title my 1.8T hesitates just as the turbo is kicking in at 3000RPM upon flooring the accelerator mainly in 2nd but also in 3rd gear.
At first I thought it was the common misfire symptoms that everyone else has pointed to. I have checked the turbo pipes all seems fine and I dont think it is the coil packs or spark plugs etc. I wouldn't describe it as a misfire or any kind of electrical fault.
It is definitely more like a very strong hesitation causing the whiplash jerking that others speak of.
I have narrowed the problem down and find it only happens when I accelerate hard with 1/4 of a tank or less of petrol. So my question is do you guys think it is fuel related and do I need to get myself an orange clip on my filter as maybe this is the cause????
This problem ruins what otherwise is an excellent drive when working correctly.
Any help much appreciated
MR (Z)T is offline
post #2 of 14 (permalink) Old 10-05-2010, 08:52
Car: Jaguar X-Type Sport 2.5 V6. Peugeot 207 Verve 1.4 2010.
It could be the manifold pressure sensor, number 6 on this grid. http://www.rimmerbros.co.uk/Item--i-GRID001691 They sometimes give that sort of problem. Or it could be sucking air in around the throttle body?
mgnev is offline
post #3 of 14 (permalink) Old 10-05-2010, 11:19
A definite yes I'd say. It may or may not not be the current problem, but you will eliminate a major cause of poor fueling.
TC
T-Cut is offline
post #4 of 14 (permalink) Old 10-05-2010, 12:13 Thread Starter
Originally Posted by mgnev View Post
If these were the problem, wouldnt this happen all the time? and not just when there is little fuel in tank?
MR (Z)T is offline
post #5 of 14 (permalink) Old 10-05-2010, 13:06
Car: MG6, Stepway, XF
could be the fuel pumps (If it works the same was as the dervs?)
Figo is offline
post #6 of 14 (permalink) Old 10-05-2010, 13:51
Possibly. I'm going on what I've read on here in the past. I did read a post that someone had a problem much as you describe, replaced that sensor and it cured it.
mgnev is offline
post #7 of 14 (permalink) Old 10-05-2010, 14:46
Trader Supporter
Car: MG Express (Van)
Turbo vac and boost pipe oil swollen and sucking in air almost definately
www.tsautos.com
ts autos is offline
post #8 of 14 (permalink) Old 10-05-2010, 14:58 Thread Starter
TS would this happen when fuel tank is low only?
Anyone got diagram of the turbo with the pipes labelled?
...and where would one get replacements?
MR (Z)T is offline
post #9 of 14 (permalink) Old 10-05-2010, 15:04
Trader Supporter
No all the time under load if it's not the filter syndrome, it'll be this it's repairable with a smaller pipe insert or cable tie
www.tsautos.com
ts autos is offline
post #10 of 14 (permalink) Old 10-05-2010, 15:08 Thread Starter
Ok will try both, just got to figure where to put the cable tie(s)...
MR (Z)T is offline
post #11 of 14 (permalink) Old 10-05-2010, 16:49
Trader Supporter
See the post boost problem on this page it shows the pipes I'm talking about
www.tsautos.com
ts autos is offline
post #12 of 14 (permalink) Old 10-05-2010, 22:52 Thread Starter
Thanks TS do you mean this thread
1.8T 75 Estate - boost issues ?
If so whats the best position to sort the white pipe on the wastegate and should i need to remove anything?
MR (Z)T is offline
post #13 of 14 (permalink) Old 06-11-2014, 18:32
Car: MG ZT
1.8t Engine Picture
Would someone be able to do me a massive favour. I need a picture of a 1.8t Engine bay. Recently had the engine replaced but not able to find out where one of the vac pipes from the turbo goes.
bowdav1 is offline
post #14 of 14 (permalink) Old 06-11-2014, 20:41
Does this help?
In this image, 'pipe' means both pipes.
TC
T-Cut is offline
hesitation on acceleration davecooper MG ZS / Rover 45 & 400 7 23-05-2008 18:53
Rover 75 1.8t Club- misfiring on hard acceleration Old Roverian MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 06-07-2005 12:40
hesitation on acceleration spikes Others 2 29-04-2005 15:15
Hesitation on Standing Start Acceleration vitessecoupe Others 5 03-06-2003 13:20
Hesitation on Standing Start Acceleration vitessecoupe Others 0 02-06-2003 10:26
