Another light question - warning light on... - MG-Rover.org Forums
post #1 of 14 (permalink) Old 22-11-2016, 08:20 Thread Starter
My blown bulb warning light is permanently on. I've checked all of the lights, and they're all ok. Any ideas? (One was blown, but was replaced several days ago now).
Will this be an MoT issue if not resolved?
JensenHealey is offline
post #2 of 14 (permalink) Old 22-11-2016, 10:07
Check the rear /tail bulbs. If one fails, the corresponding brake bulb will be used at reduced voltage. It's not always obvious unless you look carefully. The tail lights each side will shining be from different positions in the lamps. Also check the numberplate bulbs.
TC
T-Cut is online now
post #3 of 14 (permalink) Old 23-11-2016, 07:28 Thread Starter
TC
Nope, double-checked last night. All lamps illuminated. #puzzled. Any thoughts on the MoT issue?
post #4 of 14 (permalink) Old 23-11-2016, 09:07
Is there an led bulb somewhere?
From autobulbs about their led bulbs: "These bulbs are CAN-Bus compatible, meaning they can communicate with the ECU on modern cars, meaning the correct bulb behaviour, and preventing the bulb-out warning lights on your dash."
deebee is offline
post #5 of 14 (permalink) Old 23-11-2016, 09:21 Thread Starter
No again. Tried one on the wife's 45 once - no warning light, but the bulb flickered constantly.
post #6 of 14 (permalink) Old 23-11-2016, 18:30
Car: MG ZT-T
So did the warning light occur immediately when you replaced the bulb ?
Rockerbox is offline
post #7 of 14 (permalink) Old 24-11-2016, 08:50 Thread Starter
Yes, it basically just stayed on, i.e. it was on to show that a bulb had failed, and never went out even after replacing the bulb.
post #8 of 14 (permalink) Old 24-11-2016, 09:11
Maybe worth doing the 20 minutes off battery disconnection ritual. It seems to resolve lots of electrical issues, but not all by any means.
Check the usual precautions before doing this.
TC
T-Cut is online now
post #9 of 14 (permalink) Old 24-11-2016, 10:35 Thread Starter
TC
Which leads to a very obvious next question!
post #10 of 14 (permalink) Old 24-11-2016, 11:13
OEM satnav? Run the full shutdown procedure.
Radio code? Make sure you have it and know how to enter it if necessary.
Other DIY accessories requiring constant power?
There may be others I can't recall, but it's all on record if you look for it.
Perhaps use a 'code keeper' type battery gizmo in the cigar lighter?
TC
T-Cut is online now
post #11 of 14 (permalink) Old 24-11-2016, 11:31
TOAF?
Shawn is offline
post #12 of 14 (permalink) Old 24-11-2016, 16:45
Originally Posted by Shawn View Post
TOAF?
I'd love to know. Can you tell us?
TC
T-Cut is online now
post #13 of 14 (permalink) Old 24-11-2016, 16:51
TC
My car failed its MOT on a number plate bulb. Its the first time I've ever let a garage do my MOT work cost me 9 but saved me from having to re-book and bring it back.
But I thought it strange the car hadn't told me about it.
I ran TOAF and sure enough it flagged it up as an error
Shawn is offline
post #14 of 14 (permalink) Old 26-11-2016, 16:58
Car: 2004 Contemporary SE CDTi
Send a message via AIM to steven_keyte Send a message via MSN to steven_keyte
If you still have the issue with the warning light, I've had a couple of issues, which I solved which may help you:
1). Remove the rear light bulb holder unit, reove all the bulbs and clean the contact points of the holder with a fibreglass pen, this will remove any surface corrosion which may be giving a high resistance (had this issue a few times).
2). separate the rear light wiring loom plug, again, clean the prongs on the plug and spray with a switch cleaner (it took me ages to solve this problem the first time it happened!)
Hope this helps,
Steve
steven_keyte is offline
warning light question hellkef MG ZS / Rover 45 & 400 2 03-10-2012 13:31
Light Bulb Warning Indicator ON - Air Bag light ON & Brake Pad sensor Light ON! Rover-in-Spain MG ZT / Rover 75 (Sponsored by Rimmer Bros) 33 22-07-2010 20:45
warning light question??? m33ufo MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 08-06-2007 15:41
Batery Warning Light Question northstand MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 01-05-2007 19:42
