bonnet being diffucult at opening - MG-Rover.org Forums
post #1 of 4 (permalink) Old 23-05-2017, 15:43 Thread Starter
Car: 75
idk how it's supposed to be but i really have to pull the bonnet release lever up to unlatch it, i almost aloways have to pull it up twice as it wont unlatch the first time even though i hear the thud, always with excessive force to the point that the bonnet release thingy has took set tilted up. should i be greaseing a part?
pingpong is offline
post #2 of 4 (permalink) Old 23-05-2017, 17:35
i would remove it and give it a good clean as much as possible then give it a good greasing . close the latch and open it a few times while you have it off as well to work some of the grease into the pivot and latch points then wipe of any excesss and refit , also check the bonnet stops on the slam panel to see if they have been adjusted or moved and making the bonnet go tight to the catch on the lock,
Andy400 is offline
post #3 of 4 (permalink) Old 24-05-2017, 16:10 Thread Starter
Car: 75
do u know of a guide on how to remove it?, i can see the cabling on the side of the engine bay. the spring thingys on the bonnet is pretty sticky with stuff
pingpong is offline
post #4 of 4 (permalink) Old 24-05-2017, 17:23
if i remember its a couple of 10 mm bolts that holds it on the panel ,i left the cable attached and worked on mine at the car , if i remember correctly the cable pulled and unclipped if had wanted to do it but mine just needed a quick clean and grease so didnt bother removing it totally , as you say the cable just unclips from the metal holders along the panel.( how ever mines a 400 not the zt or 75 so not sure if its covered by the bumper on yours sorry ).
Andy400 is offline
Opening bonnet? Meths MGF and MGTF (Sponsored by MGFnTFBITZ) 3 27-02-2013 12:04
bonnet not opening ZR-kris MG ZR / Rover 25, 200 & Streetwise 0 04-10-2011 16:19
Bonnet not opening. jambo98 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 18-05-2010 20:36
bonnet not opening paul henery MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 08-07-2008 20:59
Bonnet Opening finly MGF and MGTF (Sponsored by MGFnTFBITZ) 6 22-12-2006 15:10
